foxrider603 Posted July 27, 2013 Report Share Posted July 27, 2013 How can i get dull plastics back to new condition Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted July 27, 2013 Report Share Posted July 27, 2013 Sand and clear coat Quote Link to comment Share on other sites More sharing options...
ericdoedoe Posted July 27, 2013 Report Share Posted July 27, 2013 penutt butter, sand it with 800 grit sand paper then buff it( they way i did mine) buy some new ones, use a blow torch that also works, put it on low dencity and go over the plastics slowly and you can see it come back shiny, use a heat gun takes longer than a blow torch but if thats all you got then go for it, Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted July 27, 2013 Report Share Posted July 27, 2013 One of those buffing kits for head lights maybe? Quote Link to comment Share on other sites More sharing options...
ericdoedoe Posted July 27, 2013 Report Share Posted July 27, 2013 Novus Polish Kit, Plastic Polish & Scratch Remover thats what i used, then i rented a buffer that plugs into your air compresser, the ones they use to buff paint, hope this helps bro Quote Link to comment Share on other sites More sharing options...
Chris327 Posted August 1, 2013 Report Share Posted August 1, 2013 wet sand, buff, polish... and wallah Quote Link to comment Share on other sites More sharing options...
foxrider603 Posted August 1, 2013 Author Report Share Posted August 1, 2013 penutt butter, sand it with 800 grit sand paper then buff it( they way i did mine) buy some new ones, use a blow torch that also works, put it on low dencity and go over the plastics slowly and you can see it come back shiny, use a heat gun takes longer than a blow torch but if thats all you got then go for it, So do i just smear the peanut butter on the plastics then sand the peanut into the plastic..... sounds alittle out there Quote Link to comment Share on other sites More sharing options...
toytech Posted August 4, 2013 Report Share Posted August 4, 2013 wet sand then clearcoat. Quote Link to comment Share on other sites More sharing options...
