Jetting alky ?
I'm almost done building my drag bike. It's a 485 cheetah with 39s and sb off cpis. Dumps are drill to 120. What size main and pilot jet should I start with and what needle?
Yes they have power jets. Now I'm pretty new to this stuff. How is it the needles work? I believe there is dgh needles in it now. Is the richer or leaner than what you said.
That needle is leaner than an E needle. The further towards the end of the alphabet you go, the richer. Start with your power jets wide open, which is the screw is backed all the way out. On alky you aren't looking for the color as you are more looking at the plating on the plug and the strap. The plating will tell you where your fuel is at the strap will tell you about your timing.
Where you are looking at the plating it is on the flat ring end of the plug. All plugs are plated in nickel or zinc I believe. Anyhow the ground strap is welded to that ring. As you get you fuel mixture right the plating will start to burn off of the end of the plug.
Notice in this picture how there is roughly 40% of the plating still on the end of the plug. A safe tune is around 25% left. I shoot for around 5% left for my drag bikes.
So with the plating.... Say you have more that 25% plating on it. Does that mean your rich or lean.
No, that means your air fuel mixture is close to stoich at wot. With alky, being rich the plug will have no plating burned off, or you'll see raw fuel out the pipes. If you are burning plating then your tune up is close to where it should be. What kind of timing are you running?
