Banshee stumbles from 2/3 to WOT
rg97
Hi all
Just put a 15 tooth sprocket on the front, running a 39 rear. It ran fine before on a stock sprocket, and now whenever im in my yard (wet grass, 75 degrees, 1200 ft, 80% humidity) it will stumble anytime i have the throttle from 2/3 to wide open in any gear other than 1st. We think it may be running lean, and its not getting enough fuel to run properly. Can you help me?
