Mikuni 34 tms
I just picked up a 421 cub with 34 mikuni Tms carbs.I need new needles so while it was apart i checked the dump tubes.it has the Q2 .... i have read that i need a q0. I'm not real familiar with mikunies. Just wanting to see what's working for others with this carb. I'm running CPI in frames.
Have you tried the bike yet? You will most likely want the Q0 tubes, but depending on your elevation and the cylinder you may get it right with the Q2's. If it has the original 5FP17 needles that is. Other needles will affect the midrange delivery. If you have the 5FP17's in there run them on the second leanest clip position with the Q-2's to start with. You may end up dropping the needle all of the way. PM me or give me a call if you need any advice.
-Brandon
