kedge82 Posted July 13, 2013 Report Share Posted July 13, 2013 ok so i got tors removed with 30 p in right now about 1 3/4 out put in 25's to see if there could be an improvement on my low end but they also had to be turned out 1 3/4 turn with no sign of differnce. now how could to differnt piloets get thesame outcome? any help or ideas? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted July 13, 2013 Report Share Posted July 13, 2013 Well are you just putting them in and reving the bike in place or riding and putting a load? Quote Link to comment Share on other sites More sharing options...
kedge82 Posted July 13, 2013 Author Report Share Posted July 13, 2013 not doing any real riding just around the block. i let it warm up try to adjust idel get it to stay running and in descent sound at an idel then run it around the block about 1/4 mile strech and go from there Quote Link to comment Share on other sites More sharing options...
Free yellow banshee Posted July 13, 2013 Report Share Posted July 13, 2013 I'm having a similar issue. I can't get the airscrews to have any effect on the motor. T5's, vf4's, ported cylinders, cfm airbox with k&n's, and boss intake. Ride at sea level. 27.5 pilots in right now and the air screw does nothing. Quote Link to comment Share on other sites More sharing options...
LCW Posted July 28, 2013 Report Share Posted July 28, 2013 Pilots only control from idle to a quarter throttle. Are you having a bog off idle orsomething else like the motor loading up and dying at idle? Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted July 28, 2013 Report Share Posted July 28, 2013 I'm having a similar issue. I can't get the airscrews to have any effect on the motor. T5's, vf4's, ported cylinders, cfm airbox with k&n's, and boss intake. Ride at sea level. 27.5 pilots in right now and the air screw does nothing. You need 30's for your pilots. You are lean....so airscrew can't help because every setting in lean. Normally a motor like yours might be happy with 27.5's, but the V-4's need more fuel so one size larger pilot is required. Quote Link to comment Share on other sites More sharing options...
Free yellow banshee Posted August 12, 2013 Report Share Posted August 12, 2013 You need 30's for your pilots. You are lean....so airscrew can't help because every setting in lean. Normally a motor like yours might be happy with 27.5's, but the V-4's need more fuel so one size larger pilot is required. Sounds good. I will order some 30's and see what happens. Thanks Quote Link to comment Share on other sites More sharing options...
Free yellow banshee Posted August 13, 2013 Report Share Posted August 13, 2013 Just went out there and messed with it some more. I think I'm to rich with the 27.5 pilots. Bike starts first kick, idles good, and has normal smoke. When I pull the choke out halfway it gets worse! Should I order some 25 pilots? Quote Link to comment Share on other sites More sharing options...
Free yellow banshee Posted August 13, 2013 Report Share Posted August 13, 2013 Are pilot jets banshee specific? This says that they are. I thought a pilot for a mikuni vm 26 would be fine. http://www.dfn.com/agservices/jetfaq.html Quote Link to comment Share on other sites More sharing options...
Young Guns Racing Posted August 14, 2013 Report Share Posted August 14, 2013 PM me your email address and I well send you a document for tuning keihin carbs (same concept) and its very clear on the pilot circuit. Maybe that will help put you on the right direction Quote Link to comment Share on other sites More sharing options...
Free yellow banshee Posted August 16, 2013 Report Share Posted August 16, 2013 PM me your email address and I well send you a document for tuning keihin carbs (same concept) and its very clear on the pilot circuit. Maybe that will help put you on the right direction Thanks Johnny. I think I figured it out though. I took it out for the first time yesterday and did some tuning. I still have the 27.5 pilots in with the air screw out .5 turns. I'll be putting in 30's soon. I know how to jet carbs, but this had me stumped. Usually if the air screw has no effect the pilot is way off in either direction. I think what happened was when I first fired it up I had the slides in backwards. After I realized it and fixed them the pilots have have been loaded up. So the first time I tried to take off I had a really bad lean bog. I had them set at 1.5 turns out. All good now. Motor is air tight btw. Thanks again. Quote Link to comment Share on other sites More sharing options...
Young Guns Racing Posted August 16, 2013 Report Share Posted August 16, 2013 Good deal. Between .5 and 2 turns out is optimal. I think your pilots are good dude. No need to go a size up if you ask me Quote Link to comment Share on other sites More sharing options...
Free yellow banshee Posted August 16, 2013 Report Share Posted August 16, 2013 Well the only reason I was considering going up a size is because when the weather gets cold I will have to close them some. Not much room to work with at .5 turns out. Quote Link to comment Share on other sites More sharing options...
