Hooptiee Posted July 12, 2013 Report Share Posted July 12, 2013 I have a 93 I'm currently putting back together and need to get a stator, Thinking about getting a racetech but will have to splice in a newer style connector. Is there any other stators besides oem that are worth screwing around with, Thanks for your input Quote Link to comment Share on other sites More sharing options...
Sandking Posted July 12, 2013 Report Share Posted July 12, 2013 Dynatech Quote Link to comment Share on other sites More sharing options...
Sandking Posted July 12, 2013 Report Share Posted July 12, 2013 Not dyna sorry buy a stock one or good used Quote Link to comment Share on other sites More sharing options...
tdod101 Posted July 12, 2013 Report Share Posted July 12, 2013 Ricky Stators kick ass LOL Quote Link to comment Share on other sites More sharing options...
Starwriter Posted July 12, 2013 Report Share Posted July 12, 2013 Quote Link to comment Share on other sites More sharing options...
Hooptiee Posted July 12, 2013 Author Report Share Posted July 12, 2013 Went with a Racetech Electric Stator since they are a Sponsor figured I would give them a try Quote Link to comment Share on other sites More sharing options...
2strokeshees Posted July 12, 2013 Report Share Posted July 12, 2013 You will be very pleased with the racetech. Im currently running 2 and there is no flaws at all. Great customer service as well. Quote Link to comment Share on other sites More sharing options...
Hooptiee Posted July 12, 2013 Author Report Share Posted July 12, 2013 (edited) I hope I have the same luck and don't have any issues, I have 3 oem stators and they are all bad, just getting the shee put back together after splitting the cases to fix a welded clutch ball and wanted no issues when it fires up Edited July 12, 2013 by Hooptiee Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted July 13, 2013 Report Share Posted July 13, 2013 I have 3 oem stators and they are all bad, How? Quote Link to comment Share on other sites More sharing options...
Hooptiee Posted July 13, 2013 Author Report Share Posted July 13, 2013 2 of the 3 were from a parts lot I bought, the one on the banshee before the dismantle would miss at high rpm's, and got rusty while it sat. I used a multi meter on all 3 not that I know how to use the damn thing, and had these readings with the stators on the bench using connector terminals. Stator 1 yellow to black wire nothing, white/red stripe - white/green stripe 118, green - red 18, Stator 2 yellow to black - nothing, white/red - white/green - 118, green - red 16. Stator 3 yellow to black nothing, white/red - white/green 121, green - red 18. I don't know if I tested them right but the yellow to black didn't give a reading on all 3. when I rebuilt the top end last year my builder put the quad on his dyno and it showed the miss on it also which he told me that it might possibly be the stator. With my luck all 3 are good, lol Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 13, 2013 Report Share Posted July 13, 2013 Those readings are all good. On the yellow to black your ohmmeter should read between 0.26 and 0.38 Ohms, darn near zero, maybe your tester wasn't set to the correct value range, that is the lighting part anyway. My meter has a tone at zero and it sounds on known good lighting stator circuits Green to red on stator Your ohmmeter should read between 13.7 and 20.5 Ohms The striped wires from the pickup coil You should have between 94 and 140 Ohms I pretty sure you have 3 good stators but the high end miss, who knows, my bet would be plug wires, or caps, but could be anything breaking up. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted July 13, 2013 Report Share Posted July 13, 2013 Have you given the flywheel a good shake and listen for a rattle? Quote Link to comment Share on other sites More sharing options...
Hooptiee Posted July 13, 2013 Author Report Share Posted July 13, 2013 Guess I should of waited to buy that new stator never thought of the flywheel rattling, I have 2 flywheel's and they both rattle. I retested the 3 stators I have with my multimeter on the 200 setting and still nothing on the yellow to black wire so my meter must not go that low. Looks like I'll throw a couple of these stators on ebay and buy a flywheel. Thanks everyone for your input Quote Link to comment Share on other sites More sharing options...
RaceTech Electric Posted July 23, 2013 Report Share Posted July 23, 2013 Glad to see alot of our customers here. Thanks again for all your support guys! 1 Quote Link to comment Share on other sites More sharing options...
