mx1986 Posted July 11, 2013 Report Share Posted July 11, 2013 I have a trex with a couple base gaskets spacer plates on it and was wonder when u put multiple plates and spacers how do u get the jug nuts to keep the thing together without it rattling lose. Loctite? Quote Link to comment Share on other sites More sharing options...
toytech Posted July 12, 2013 Report Share Posted July 12, 2013 why do you have mulyiple plates? if you use good quality gaskets it should not be a problem. you could get ahold of a shop that rebuilds air compressors they can get hard gasket material. Quote Link to comment Share on other sites More sharing options...
camatv Posted July 12, 2013 Report Share Posted July 12, 2013 true the crank, check for deto, use metal formed gaskets, OR custom cut copper, convert to a hardened stud case and hardened nut/ washer combo. to me the t-rex dosent have a weak ass head design (neither does the cheetah) so the next weak link is the case studs. had this happen on a 535. head wouldnt lift so it would lift the cylinder off the case. would break the inner studs and rip the threads right out of the nuts. not sure if this is your same problem. motor was making a lot of internal pressure.. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 12, 2013 Report Share Posted July 12, 2013 Interesting...... If one were doing a cheetah would it be wise to remove stock base studs, and heli coil the cases from the get go and use arp studs? Quote Link to comment Share on other sites More sharing options...
camatv Posted July 12, 2013 Report Share Posted July 12, 2013 i made my own hardened case studs. the motor i had these issues with was my own and i pushed it pretty damn hard.. after the case studs stopped ripping out it actually pushed the head up over the brass washers! that was really cool... switched to grade 8 flanged nuts and sealed the threads and that stopped.. i have seen a lot of cases in my opininion done badly and the base gasket has almost NO sealing surface to hold against. they then rip the cheap ass thin paper gaskets out and blamo! air leak-big lean out- bye bye motor i wish ARP would do more with metric threaded stuff.. i'm suprised at the small amount they have now. there is a bunch of m10 stuff but not much in the way of m8. instead of helicoils maybe timesert's? i think thats what you call them.. Quote Link to comment Share on other sites More sharing options...
