black sunshine Posted July 9, 2013 Report Share Posted July 9, 2013 The longest one that seals the two halves has 1/2" "inch worm" when put in the groove. Any ideas? I could cut and superglue it, but I think this would make a hard spot that may leak. Also, I have one loner that is 2 1/2" in diameter? Chariot racing brand o-rings. First time with this, I hope I don't have to order new ones without even using these. CAN ANYTHING GO RIGHT WITH THIS BUILD!!!?????? Thanks for the help! Quote Link to comment Share on other sites More sharing options...
toytech Posted July 10, 2013 Report Share Posted July 10, 2013 use silicone grease on the o rings and work them around, they fit. do not cut them. Quote Link to comment Share on other sites More sharing options...
Tedder Posted July 10, 2013 Report Share Posted July 10, 2013 I agree with toytech... Sometimes they seem long / somestimes short. I spray them with whitegrease and as the carrier dries off they get sticky and will stay down. Quote Link to comment Share on other sites More sharing options...
black sunshine Posted July 10, 2013 Author Report Share Posted July 10, 2013 I used O-ring grease on them. I will let you know if it shrinks. Anyone know where the single 2 1/2" one fits? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted July 10, 2013 Report Share Posted July 10, 2013 I used O-ring grease on them. I will let you know if it shrinks. Anyone know where the single 2 1/2" one fits?That shod be used in the prodesign all that way around the top piece I believe. Quote Link to comment Share on other sites More sharing options...
Finch Posted July 10, 2013 Report Share Posted July 10, 2013 Vaseline works good Quote Link to comment Share on other sites More sharing options...
Pastrykiller Posted July 10, 2013 Report Share Posted July 10, 2013 Finch - Why do you even have Vaseline? Quote Link to comment Share on other sites More sharing options...
Finch Posted July 10, 2013 Report Share Posted July 10, 2013 For o rings Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted July 11, 2013 Report Share Posted July 11, 2013 For o rings POW Quote Link to comment Share on other sites More sharing options...
Pastrykiller Posted July 11, 2013 Report Share Posted July 11, 2013 Well played sir. Quote Link to comment Share on other sites More sharing options...
black sunshine Posted July 12, 2013 Author Report Share Posted July 12, 2013 Been a while since I've been on here, glad to see everyone's mind is still in the gutter!!!!!! Got the long o-ring to fit. Hoping they threw a few extra o-rings in for other types of heads because I have a few extra. Quote Link to comment Share on other sites More sharing options...
Chariot Performance Posted July 16, 2013 Report Share Posted July 16, 2013 Yes on extras. When putting orings in grooves do not use silicone because it does not allow for oring squish and the oring will fail guaranteed. Use grease to hold orings in place. If you SLIDE your finger along the oring as fitting it in the groove then it will stretch and be too big to fit. Move your finger up and down as you put the oring in the groove. Jerry 1 Quote Link to comment Share on other sites More sharing options...
