K&n Clamp On Filters With Stock Pipes?
I have a 2004 stock banshee, I have clamp on K&N filters, at Sea Level, with stock pipes, and removal of TORS. what would be a good starting point for jetting???eventual plans are for a set of CPI inframes. but that may wait til next season...but I have the filters now. and would like to use them.
Stock pipes do restrict, but in certain areas of the rpm range. I have heard of people porting a motor out, using stock pipes and smoking others with just pipes. If you already have the filters by all means use them. If you have the stock airbox on there now, you will notice a difference for sure. Not everybody has the money to put on pipes and all the goodies. I'm glad to see you sticking to the rules in your area also. That's the attitude that will keep our sport alive. You will hear a lot of intake noise with the air filters, but nothing like pipes. I'd go for it.
  • 8 months later...
leave yor pilots and needles alone, and your air screw is just an idle adjustment. if your concerned about it, just twist in and out until you find the spot it idles best and has best response.
because of our new noise restraints and spark arresteer issues
what are the noise restraints, surely like 98 or something.
Edited by sredish
  • 6 years later...
