demonspeeding1 Posted November 2, 2003 Report Share Posted November 2, 2003 I WAS WONDERIN WHAT THE DIFFERENCE BETWEEN CARBS ARE... LIKE FLATSLIDE AND ALL THEM AND WHAT THE BEST ONES TO GET ARE LIKE SIZE AND FLATSLIDE OR NOT AND IF I HAVE TO MOD. ANYTHING IF I GO TO A BIGGER SIZE? THANX FOR ANY INFO Quote Link to comment Share on other sites More sharing options...
PassionRE Posted November 2, 2003 Report Share Posted November 2, 2003 Flatslides provide better throttle response. As for size, if your mods are done properly you can go with bigger carbs and lose little to no throttle response. I personally prefer the Keihin carbs, they just seem to dial in alot easier...Jim Quote Link to comment Share on other sites More sharing options...
demonspeeding1 Posted November 2, 2003 Author Report Share Posted November 2, 2003 what about the 2 into one carbs?? do those work better?? as for size what should i get? i have pro circuit pipes, v-force reeds and spacers, boost bottle, over sized radiator, thats pretty much it for now... what size carbs should i get? and what kind? Quote Link to comment Share on other sites More sharing options...
PassionRE Posted November 2, 2003 Report Share Posted November 2, 2003 With that set-up, I would reccomend the PWK33 Keihin's. That way later down the road when you decide to port your motor for more power, and you will, you will have enough carb to handle the additional intake flow requirements of your porting...forget the single carb, to me, thats almost sacrolige...Jim Quote Link to comment Share on other sites More sharing options...
demonspeeding1 Posted November 2, 2003 Author Report Share Posted November 2, 2003 kool... what is PWK stand for?? is the 33's you were talkin about are they flatslide or?? Quote Link to comment Share on other sites More sharing options...
PassionRE Posted November 2, 2003 Report Share Posted November 2, 2003 PWK stands for PART WITH your KASH. yes, flatslide design....really nice carbs...Jim Quote Link to comment Share on other sites More sharing options...
demonspeeding1 Posted November 2, 2003 Author Report Share Posted November 2, 2003 would i need any mods to put those carbs on? or should they fit right in?.... would they work with my v-force reeds and spacers? one last thing... how should i jet them with the way i have my set up now..? i live in michigan so air isnt to thin at all (if that matters) Quote Link to comment Share on other sites More sharing options...
PassionRE Posted November 2, 2003 Report Share Posted November 2, 2003 Whats your elevation? The carbs will fit your manifolds although they will stretch out a little and eventually you will be forced to upgrade those manifolds. Your reeds are just perfect and will do nothing but make those carbs work their best. I would guess stock pilot ,and around 160-170 on the main for a slightly rich mixture...Jim Quote Link to comment Share on other sites More sharing options...
demonspeeding1 Posted November 4, 2003 Author Report Share Posted November 4, 2003 thanx for the help...... any other info would be nice..... Quote Link to comment Share on other sites More sharing options...
Banchetta Posted November 4, 2003 Report Share Posted November 4, 2003 Putting carbs on w/o porting will lose performance. Trust me. I spent over 350 bucks to lose 8hp using 34mmPJ's...... Even ported stock carbs lost performance. the stock intake is perfect w/ the stock carbs. If you plan on porting later, the hold off and buy the carbs after you decide on what port to go with..... Quote Link to comment Share on other sites More sharing options...
demonspeeding1 Posted November 5, 2003 Author Report Share Posted November 5, 2003 well i need some carbs NOW cause mine are junk and all that .... so if i have to get new ones i might as well get good ones ... and i plan on porting and upgrading in the future sooo.... ?? confused again Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted November 5, 2003 Report Share Posted November 5, 2003 whats wrong with your stock carbs? Also how much better are the 33mm PWK flatslides keihin's vs the 34mmPJ Keihin's? A local place quoted me $300 for the 34mm PJ's w/ free dyno tune. But they don't sell the 33mm carbs. I Have porting on the way thats to passionRE, so I just need to decide which to get. I have some time to decide though Thanks, JI Quote Link to comment Share on other sites More sharing options...
Blue Duece Posted November 5, 2003 Report Share Posted November 5, 2003 well i need some carbs NOW cause mine are junk and all that .... so if i have to get new ones i might as well get good ones ... and i plan on porting and upgrading in the future sooo.... ?? confused again Sounds like you might have to ride it sluggish for a while.....................Banchettas right your stock carbs are best suited for stock port, if you just slap bigger carbs on your otherwise stock top end your bike will loose drasticly in throttle response and power, all youll really have is a slow fuel whore, and a jetting nightmare, to lean it out right your mains will be tiny(i have a pal who tried this he's still fuckin with it) but on the other hand listen to Jim, have him port your top end and go with his recomended carb setup for his port and ill bet you'll have a rocket........ Quote Link to comment Share on other sites More sharing options...
PassionRE Posted November 5, 2003 Report Share Posted November 5, 2003 whats wrong with your stock carbs? Also how much better are the 33mm PWK flatslides keihin's vs the 34mmPJ Keihin's? A local place quoted me $300 for the 34mm PJ's w/ free dyno tune. But they don't sell the 33mm carbs. I Have porting on the way thats to passionRE, so I just need to decide which to get. I have some time to decide though Thanks, JI Justintoxicated!.....decided to drop your load huh?...go with the 33's on your port job...but honestly, get those v-force reeds first ,and if you can only get one of them now,...go for the reeds...your cylinders should be there in a couple of days, and after you get them, keep your hands where we can see them...Jim Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted November 6, 2003 Report Share Posted November 6, 2003 whats wrong with your stock carbs? Also how much better are the 33mm PWK flatslides keihin's vs the 34mmPJ Keihin's? A local place quoted me $300 for the 34mm PJ's w/ free dyno tune. But they don't sell the 33mm carbs. I Have porting on the way thats to passionRE, so I just need to decide which to get. I have some time to decide though Thanks, JI Justintoxicated!.....decided to drop your load huh?...go with the 33's on your port job...but honestly, get those v-force reeds first ,and if you can only get one of them now,...go for the reeds...your cylinders should be there in a couple of days, and after you get them, keep your hands where we can see them...Jim thx ill see if I can convince them to pickup a set of 33's just for me, then maybe I could still get the free dyno tune . I have plans to get the bottem end back together this weekend, SDD from the forum is coming by to help me out. So reeds are more important than carbs? I was thinking about just having my stock reed cages ported for whatever kind of reeds I want, as was the offer. Not sure how much difference there would be between ported cages and new ones though. Quote Link to comment Share on other sites More sharing options...
