trayfoe Posted November 2, 2003 Report Share Posted November 2, 2003 What is involved with putting a batterie in a shee, can the stator charge the batterie? How is it done? Quote Link to comment Share on other sites More sharing options...
WhiteShee Posted November 2, 2003 Report Share Posted November 2, 2003 What are u going to use the battery for? -Nick Quote Link to comment Share on other sites More sharing options...
trayfoe Posted November 2, 2003 Author Report Share Posted November 2, 2003 Well I am going to be dragin my shee on asphalt and was going to run nitrous on it in the future. I wasn't sure if the stator would have enough juice to run the solinoid or not. Quote Link to comment Share on other sites More sharing options...
BaddestBanshee Posted November 2, 2003 Report Share Posted November 2, 2003 Ricky Stator makes a battery kit. Yes you will need to run a batt to use NOS. Your charging system runs on A/C now. So you will need to run a rectifier to convert the voltage to dc. Quote Link to comment Share on other sites More sharing options...
sean10 Posted November 5, 2003 Report Share Posted November 5, 2003 I welded a metal plate to the front of the frame right under the front nose of the plastic. It fit fine right there and was easy access to recharge the battery again. Quote Link to comment Share on other sites More sharing options...
AR-15 Posted November 6, 2003 Report Share Posted November 6, 2003 Thats right where mine is sean10. I don't worry about using the stator to charge it, I just charge it up before I go out, and it lasts all weekend. Quote Link to comment Share on other sites More sharing options...
steve91932 Posted November 6, 2003 Report Share Posted November 6, 2003 I have looked in to the Ricky Stator battery kit. Its a very cool kit. Comes with everything you need. You may need to send him your stator as I have been told that some will not plug into his wiring harness. They will also try to upsell you on getting your stator rewound. I will hopefully be installing one next month so i can run HID lights. Quote Link to comment Share on other sites More sharing options...
