jscharphorn Posted July 4, 2013 Report Share Posted July 4, 2013 Like new condition, just a poor picture. I do not think it has a scratch on it and very very little use. for stock swing arm and 175 lb rider $475 shipped. Quote Link to comment Share on other sites More sharing options...
Banshee SE Posted July 4, 2013 Report Share Posted July 4, 2013 zero preload shock?? Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted July 4, 2013 Author Report Share Posted July 4, 2013 It is a stage 3 so I think compression and height adjustment only. Quote Link to comment Share on other sites More sharing options...
Banshee SE Posted July 4, 2013 Report Share Posted July 4, 2013 It is a ZPS. I think you are right Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted July 4, 2013 Author Report Share Posted July 4, 2013 If ZPS means it is missing the small spring on top it has it, Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted July 4, 2013 Author Report Share Posted July 4, 2013 Yes thanks I knew that, just saying ZPL threw me off. Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted July 5, 2013 Author Report Share Posted July 5, 2013 OK, it does have the small spring Quote Link to comment Share on other sites More sharing options...
Burke Posted July 5, 2013 Report Share Posted July 5, 2013 isn't a zero preload shock one without preload adjustments?... which this one clearly has if I am incorrect, let me know. Quote Link to comment Share on other sites More sharing options...
Banshee SE Posted July 5, 2013 Report Share Posted July 5, 2013 I used to have the same shock and i liked how the bike felt but the only thing that i did not like was how low the bike was. Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted July 5, 2013 Author Report Share Posted July 5, 2013 Elka says the bike should be about 8 3/4" off the ground, the shock can be adjusted to raise or lower by the spring adjustment. Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted July 6, 2013 Report Share Posted July 6, 2013 http://bansheehq.com/forums/index.php?showtopic=155661&hl= Quote Link to comment Share on other sites More sharing options...
