cdi and coil placement
i Know this must sound stupid. but i need help! i bought my shee as a basket case and now i have no clue where the wire harness, CDI, coil, or regulator go. also im lost as to how the fluid container is locked down... a bracket of sorts i dont know. ive done a lil looking but all i can find is relocating brackets to the front end which is no help to me. just curious if someone has or could take a pic to help me out?
Here you go. You can't see it, but the single wire voltage regulator goes to the right of the CDI, bolted to those 2 captive nuts. The ground wire ring terminal goes on 1 of the regulator bolts. The wire harness to the rear goes along the right side of the air box. If you are running pods, make sure the harness doesn't get against the right exhaust stinger. Throw the overflow bottle in the trash. You don't need it.
Edited by Starwriter
