Trying to understand Gearing
2strokes4u
Can someone explain tall gearing vs short gearing. I drag race on asphalt and was wondering how the gearing effect torque. I am running a 17t front and 38t rear. I run on the street and the gearing is damn near perfect for the 1/8th mile. What I am wondering is if I go to an 18t front, will that increase the pull down low, up top or all around?
I ran the 18 before and motor can pull it with no problem. I guess I need to get it to the track and try both  sprockets and see what the times look like. I was just curious because I am running bigger bikes now and i want as much pull as possible across all gears.
I ran a 10 mil cub ported on alky, stock head without a wheelie bar and that was his mistake. I jumped out on him and never saw him again. I have a 7mil on race gas (unported).
I know that he next time he will have a wheelie bar and it should be a better race. I plan to get ported and alky in fall. For the time being I thought that I would play with gearing to see if i could get a better pull through all gears.
Going to a 18 you will lose the pull down low & increase your top end if your motor can pull the rpm needed.
Your 17/38 gearing is a good combination depending on your primary gears, tire diameter & weight to name a few.
We run a 17/36 (2.12 ratio) for both 1/8 & 1/4 mile. That was with our old 443 gas cub. We would fine tune the gearing + or - of that ratio for track conditions & air readings to name a few.
I have the same question as well. I think the 18 up front will give u more topend and less spinning off the start. U just have to have the motor to pull it
You answered your own question, LOL!
You should send SlowerThanYou or Tedder a PM. They will both be able to help you with this. Or link them to this thread.
Thanks!
R u in Florida
No, Do my racing in NC.
Thanks!
Thanks,, I have banshee sprocket hub now but would like to get honda hub to try 36t in the rear. Figured I would just wait until I get the drag axle instead of wasting time getting a hub for stock axle. My primary gears are stock ratio straight cuts, running an 18 inch tire and bike is heavy as hell...stock chassis and I am 215lbs.
The biggest difference in our set-ups is the tire diameter. The 18/38 (2.11 ratio) should be an improvement with a few other adjustments.
