350 setup questions.
BANSHEEBEEFM2M
Since you are heavy, don't bother with the lightened flywheel. It only seems to work with light bikes and itty bitty jockeys. And ditch the Vito's degree key and just get an adjustable plate. Way easier and you can change it. And if you are doing a good triple exhaust port(RDZ?) you will probably be happier with some 39's on there.
id run 38/40 lectrons and go back to alky.  OR 40/40 OR 41/44's
run as much timing as your domes can handle on gas or alky.  and i really hope your going to run an override??  all drag 350's really really really benefit from overrides.  they let the motor stay wound up and in my opinion make them much faster.  custom domes and loose squish than normal  you need to let it REVVVVVVVVV
loose as much weight off the chassis as you can.
8-12 paddle hauler depending on situations.   on my wife's 350 rider i run 12's on flats. with a +6 its a bear to keep down at times.  no lockup ( 9 plate clutch tho)  the chassis is a full weight/ steel axle suspended bike.
  • Like 1
