mhoksch Posted June 26, 2013 Report Share Posted June 26, 2013 I just dropped my frame off last night for powdercoat. The guy was telling me he does alot of ceramic coating on exhaust. Told me it'd only be about $200 to do my pipes. I've got SB IF Shearers, chrome is chipped in a few tiny spots. Are there any benefits to ceramic coating on the pipes? How durable is the ceramic? Quote Link to comment Share on other sites More sharing options...
5150banshee Posted June 26, 2013 Report Share Posted June 26, 2013 If you talk to Matt he will tell you to ceramic them not powder coat them the powder changes the performance of the pipe. Sent using Tapatalk Quote Link to comment Share on other sites More sharing options...
mhoksch Posted June 26, 2013 Author Report Share Posted June 26, 2013 Ya, I'm getting powder on the frame. Thinking about ceramic on the pipes. Sent from my PB99400 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted June 26, 2013 Report Share Posted June 26, 2013 It doesn't hold up to sand. First ride they will be frosted. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted June 26, 2013 Report Share Posted June 26, 2013 If you talk to Matt he will tell you to ceramic them not powder coat them the powder changes the performance of the pipe. Sent using Tapatalk Thats strange. He told me just the opposite. Said ceramic changes the way the pipes works/holds heat , and to only paint or chrome them. Quote Link to comment Share on other sites More sharing options...
mhoksch Posted June 26, 2013 Author Report Share Posted June 26, 2013 Ok, I want my pipes to be black. Ceramic or powder coat? I'm looking for pros and cons of each, not just personal opinions. Sent from my PB99400 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
m671054 Posted June 27, 2013 Report Share Posted June 27, 2013 Paint. the other 2 you want will change pipe temp causing it to work differently. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 29, 2013 Report Share Posted June 29, 2013 If you talk to Matt he will tell you to ceramic them not powder coat them the powder changes the performance of the pipe. Sent using Tapatalk Are you sure? Because I've had that conversation with Matt on the phone when purchasing raw pipes and he told me "absolutely do not ceramic coat these pipes". That was in reference to the small bore inframe pipes. I have seen it help some pipes and hurt others. It just depends on the pipe design. OP: Don't put any thing on those pipes other then chrome or paint. Quote Link to comment Share on other sites More sharing options...
Nightmare Posted June 30, 2013 Report Share Posted June 30, 2013 If you talk to Matt he will tell you to ceramic them not powder coat them the powder changes the performance of the pipe. Sent using Tapatalk Are you sure? Because I've had that conversation with Matt on the phone when purchasing raw pipes and he told me "absolutely do not ceramic coat these pipes". That was in reference to the small bore inframe pipes. I have seen it help some pipes and hurt others. It just depends on the pipe design. OP: Don't put any thing on those pipes other then chrome or paint. He told me the same thing when I got my raw oof. Sent from my SGH-T679 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted June 30, 2013 Report Share Posted June 30, 2013 I've had 2 sets of T5's at the same time, one set chrome and a raw set I had Ceramic coated on my son's bike, we always rode together at the dunes. Both bikes had the same mods. The ceramic coated ones were always cooler, and cooled off quicker. I can't say that I knew if it would change the performance of the pipe or not. Quote Link to comment Share on other sites More sharing options...
mhoksch Posted June 30, 2013 Author Report Share Posted June 30, 2013 How durable was the ceramic? Did the sand at the dunes scuff it up at all? I'll be riding mine mostly on the ice in the winter, but might trail ride in some sandy areas 1-2 times per year Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 2, 2013 Report Share Posted July 2, 2013 I stuck very well, the sand did dull it but it would polish right back up with fine scotchbrite. I'm sure it was actually an aluminized coating, never wore through. Had them for probably 8 years, 5 or so dune trips a year. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 2, 2013 Report Share Posted July 2, 2013 I have had a couple RC 2 stroke pipes ceramic coated. I had Swain Tech do them. They use a real ceramic coating that is applied in molten form. It is ceramic powder so you can only get it in a white. You can paint it what ever color you like afterwards. It is real rough like a pumic stone. Coatings like jet hot are more of a ceramic based paint. They are applied as a liquid then cured. Quote Link to comment Share on other sites More sharing options...
mhoksch Posted July 2, 2013 Author Report Share Posted July 2, 2013 I think what I'm looking at is more of the paint style. It's cerakote Sent from my PB99400 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
