Tow angle or ?
Need some help on steering adjustments, if I put the handle bars straight the front tires look straight but it drives to the left pretty significantly, what would cause this ? Tie rod out of whack ? Also if you look at it from the front of the bike the left tire points in while the right one is straight as an arrow.
I strap my handle bars and measure in a X pattern to the back so they stay perfectly straight. Then bungee cord a cheap laser level to the outside of the rear tire pointing forward. From there, set the toe to parallel to the rear, then in a little. just can't ever seem to eyeball that stuff.
