no spark on banshee! help
ok i bought a banshee that was blown up it probally sat for 3 years so i rebuilt it went to start is and no spark so i got a cdi box no spark got a coil and i can get a spark every now and then this thing has me stumped i cleaned the stator and the pick up and put the gap back in spec plz help
i took the flywheel off the stator poles had some rust i cleaned the rust off and it has the tors on but the wires are snipped i dont have any of the switchs hooked up the main key switch is snipped off what switchs do i need hooked up for it to make spark? i sanded the coil grounds down to the bare metal i cleaned the ground on the back by the voltage regulator. are there any othere grounds other than one on the stator that needs to be clean ?
Just re-read all this and realized the mess you got going (actually not going).
For diagnostic run a ground wire from the coil back to the engine, maybe right to a stator screw, can always make something permanent later. IIRC the key switch/wires have to make contact, the kill switch wires cannot. Also make sure the TORS brain box is unplugged. Check parking brake circut if you have one, no clue on how to disable it (search function)
