PilotYFZ Posted November 1, 2003 Report Share Posted November 1, 2003 my buddies banshee will start up then automatically die it has spark when you kick it over, but if you pull it with another 4 wheeeler, it wont spark. it has new cdi,stator,coil, ok compression, it seems to be getting gas. Quote Link to comment Share on other sites More sharing options...
cb67rs1 Posted November 1, 2003 Report Share Posted November 1, 2003 put more gas in it Quote Link to comment Share on other sites More sharing options...
cb67rs1 Posted November 1, 2003 Report Share Posted November 1, 2003 NA just messing with you, it sounds like the TORS is messed up. disonnect all that junk and you should be ok Quote Link to comment Share on other sites More sharing options...
Ultimateduner Posted November 4, 2003 Report Share Posted November 4, 2003 Try putting better sparkplugs in it. That is what is usually wrong with mine. Quote Link to comment Share on other sites More sharing options...
boonman Posted November 4, 2003 Report Share Posted November 4, 2003 OK compression? Did you test it? is the fuel valve turned on? Is there gas in the tank? it has happened to me before. You say it seems to be getting fuel. Are you sure? I would try pullign the carbs apart and clean them. Is the choke tube between the carbs in place? Are the plugs fouled? Unplug the brain box for the TORS, it has 3 wires going into it, and it is under the left side of the tank... That will eliminate that as a problem. Quote Link to comment Share on other sites More sharing options...
