Fastassbanshee96 Posted June 18, 2013 Report Share Posted June 18, 2013 Where can I find intakes for my cheetah cylinders? I running 39mm carbs. I believe they are cr250 intakes or something like that. If you know of anywhere could you also please post a link. Thanks Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted June 18, 2013 Report Share Posted June 18, 2013 Any site sponsor that does motor work can hook you up. Id call Redline or White Knuckle. Quote Link to comment Share on other sites More sharing options...
Fastassbanshee96 Posted June 18, 2013 Author Report Share Posted June 18, 2013 Ok thanks. I'll be calling one of them anyway to have some domes cut. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted June 18, 2013 Report Share Posted June 18, 2013 Use the UPP intakes. 1 Quote Link to comment Share on other sites More sharing options...
shanYE west Posted June 18, 2013 Report Share Posted June 18, 2013 chariots are nice. Quote Link to comment Share on other sites More sharing options...
m671054 Posted June 18, 2013 Report Share Posted June 18, 2013 Anyone have one for larger than 40mm carbs? Quote Link to comment Share on other sites More sharing options...
shanYE west Posted June 18, 2013 Report Share Posted June 18, 2013 Anyone have one for larger than 40mm carbs? chariots are nice. Quote Link to comment Share on other sites More sharing options...
Coupelx Posted June 18, 2013 Report Share Posted June 18, 2013 I run the upp intakes. I see no reason I need a bunch of billet aluminum in there to cause leaks. They also clear the clutch arm nicely. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted June 18, 2013 Report Share Posted June 18, 2013 I run the upp intakes. I see no reason I need a bunch of billet aluminum in there to cause leaks. They also clear the clutch arm nicely. I've used UPP and it seemed like the carbs bounced around a lot and were more prone to cracking. The chariot/billet intakes seemed more sturdy. Also makes it nice that they use genuine mikuni boots so they are some what interchangeable to use with different size carbs. To ea. their own. I prefer billet intakes. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted June 19, 2013 Report Share Posted June 19, 2013 UPP intakes are made of high grade polyurethane, not rubber. They are NOT more prone to cracking. (I don't have an Opinion on the matter....I'm just stating facts.) The "Genuine Mikuni" boots however ARE made of rubber and are prone to dry rot and cracking. Billet intakes have a seam where the rubber meets the aluminum. This is double the number of seams you get with the UPP intakes. Since the UPP's are one piece and have no seams.) So expect to eventually see cracks form either at the junction on the intake or at the carb connection. But billet has bling tho...... I run UPP's and I agree.....To each there own. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted June 19, 2013 Report Share Posted June 19, 2013 I'd like to add that plasticizers are used to soften the polyurethane. fuel/oil will eventually break down and harden these plasticizers. it has the same effect on rubber. Which is what happened to my UPP intakes (they were older). We have similar problems with lane oil getting onto our distributor belts. bushings, lift wheels and other components both polyurethane and rubber based in the bowling industry. they eventually will harden, curl and crack. which is why we have to clean machines often with a cleaner that is not aggressive (I use windex) If there is constant stressing/moving with hardened plasticizers it will crack. Not saying one is better then other.. They both have the same demons. I just like the stability of the billet pieces. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted June 19, 2013 Report Share Posted June 19, 2013 You managed to reference "The bowling industry" without ever mentioning Balls. Well played. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted June 19, 2013 Report Share Posted June 19, 2013 You managed to reference "The bowling industry" without ever mentioning Balls. Well played. Hey now, I dont just work with balls... lol I'm versatile I'll save the affects of oils with high solids on bowling bowls of different materials for another day. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted June 19, 2013 Report Share Posted June 19, 2013 Please feel free to hold off on that indefinitely. I really don't want to hear you describe what kind of oils and solids you spend your days cleaning off of your balls. Don't want to hear about finger placement, the fun you have playing on oily lanes, hard wood, or how hard your balls get from all the oil either. Now before we overwhelm ourselves with bowling metaphors........I'm going to just split. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 19, 2013 Report Share Posted June 19, 2013 What the fuck. Quote Link to comment Share on other sites More sharing options...
