turbowrenchhead Posted June 17, 2013 Report Share Posted June 17, 2013 I have thrown my chain several times now while its under a heavy load going around a corner when hamming it. The sprockets and chain looks straight on the bike. What should I be looking for? Quote Link to comment Share on other sites More sharing options...
Dick Dragon Posted June 17, 2013 Report Share Posted June 17, 2013 Worn swinger and/or carrier bearings,cracks in frame and/or swinger,worn(stretched) chain just to start Quote Link to comment Share on other sites More sharing options...
Starwriter Posted June 17, 2013 Report Share Posted June 17, 2013 Are both frame chain rollers, the lower chain guide and the chain slide at the swingarm pivot all in good shape? In addition to what's mentioned above, if you're running stock style carrier, the carrier mounting bolt holes can be wallowed out. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 17, 2013 Report Share Posted June 17, 2013 Rear chain guide and bottom roller. I ripped the guide off one day riding, the rest of the day was a nightmare Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted June 17, 2013 Author Report Share Posted June 17, 2013 I'm not running a rear chain guide because of the prm skid plate. All the pivot bearings are new. New swing arm. Frame was gone over and repainted. I took a good second look at it and the top roller doesn't spin at all and its slightly out of line towards the engine. I'll have to pull the swing and inspect. The real bummer is I just changed my cases without the chain knock out. Only after a month the chain poped the case. Quote Link to comment Share on other sites More sharing options...
Dick Dragon Posted June 18, 2013 Report Share Posted June 18, 2013 Is it the same chain? You may look at the links real close too... Quote Link to comment Share on other sites More sharing options...
JUSTWANNARACE Posted June 18, 2013 Report Share Posted June 18, 2013 Do you have the lower motor struts in? Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted June 18, 2013 Author Report Share Posted June 18, 2013 Yes I have the lower motor struts in. I found the problem last night. I put a jack under it and ran it in gear to see how things looked while running. The rear sprocket bracket is bent now. I'm going to upgrade to the later model bracket. Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted June 18, 2013 Author Report Share Posted June 18, 2013 Find a way to run the chain guide, I had to run my backwards with my skid. Also make sure your axle nuts are tight. Mine would come loose and chain would pop off. Got a dual locking one and it works great. Also make sure your carrier isn't loose. Everything is tight. I looked at the rear skid and imagined how I could run a rear chain guide. I don't think there is enough clearance to run on. The problem is the bent rear sprocket collar/ bracket. Its bent. Next question is will a later model 5 spoke one swap over to my 87 axle? Quote Link to comment Share on other sites More sharing options...
Vicstuff Posted June 18, 2013 Report Share Posted June 18, 2013 Yes the late model hub will fit think I have a extra pm if interested<br /><br />Sent from my HTC_Amaze_4G using Tapatalk 2<br /><br /> Quote Link to comment Share on other sites More sharing options...
armyvet Posted June 18, 2013 Report Share Posted June 18, 2013 yesh the later hub will fit.did it myself Quote Link to comment Share on other sites More sharing options...
SOUTHTHIRTY Posted June 19, 2013 Report Share Posted June 19, 2013 Cut the skid ...they do it on Hondas Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted June 20, 2013 Author Report Share Posted June 20, 2013 I think once I get a straight hub and new rear pbi rear sprocket on it that my issues will go away. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 20, 2013 Report Share Posted June 20, 2013 Nope, you need a rear guide, I ripped mine off the beginning of the day. That day was ruined, the chain kept jumping. I'm really lucky I didn't blow my cases apart Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted June 30, 2013 Author Report Share Posted June 30, 2013 No rear guide needed. I replaced the rear hub with a later model 6 spoke. pbi rear sprocket and a new sunstar 14 in the front. I got on some hard dirt yesterday and it held up nice. Chain stayed on all day yesterday. Quote Link to comment Share on other sites More sharing options...
