3s1k Posted June 15, 2013 Report Share Posted June 15, 2013 I got my banshee used and it already had a 47t rear sprocket. Not sure if that's for lower top speed or what. I also found a 41t sprocket which I think is the stock on. Anyways what is better for all around riding? I bougt a +4 swingarm and it came with with a chain. I installed it and the chain is to short like 8-9 links and I mocked up the stock sprocket and its still short like 5 links. I even pushed the axle all the way in on the chain tensioner. Do you guys know what size chain I need or do I just count the links an add extra? Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted June 15, 2013 Report Share Posted June 15, 2013 1) Stock sprockets are 14/41......that is a damn good ratio for all around riding. Going smaller in front by 1 tooth is equal to going bigger in the back by 3 teeth. So since you have a 47 tooth...you are basically running a 12/41 style gear setup which is more aimed towards having a quick low end and no top end. 2) Sounds like the chain that came with it is meant for a stock swinger and you didn't disclose that you had a +4 swinger......Better call whoever you bought that setup from and ask them if you can return the chain and pay the difference for a chain long enough for a +4 3) We have site sponsors on the site that are super knowledgeable.....these guys eat sleep and hump banshees. If you called them, not only do they have really affordable prices......but they would have known exactly the length chain you needed. Hell....usually they send them with a few extra links so you have to trim it down to size..... Quote Link to comment Share on other sites More sharing options...
3s1k Posted June 15, 2013 Author Report Share Posted June 15, 2013 (edited) I bought the swingarm and chain of craiglist for $110 so can return the chain. I looked at the chain and it looks barely used so I don't want to spend money if I don't have too. I read of people using 2 master links here on BHQ is that advisable? I'll probably switch back to the stock gearing. I rode it ibce since I got it and it seemed to top out pretty quick. Edited June 15, 2013 by 3s1k Quote Link to comment Share on other sites More sharing options...
coryv4 Posted June 15, 2013 Report Share Posted June 15, 2013 (edited) cut 5 links out of your other stock chain and add it to this chain, use another master link until you can afford a longer chain. Edited June 15, 2013 by coryv4 Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted June 15, 2013 Report Share Posted June 15, 2013 2 masters isn't ideal but not a problem especially on low hp stuff. Be sure to put the clip on in the right direction. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 15, 2013 Report Share Posted June 15, 2013 2 masters isn't ideal but not a problem especially on low hp stuff. Be sure to put the clip on in the right direction. Hey dweeb, I run two master links on our hillclimb bikes. IF properly installed, there's nothing wrong with two masters. Quote Link to comment Share on other sites More sharing options...
possum Posted June 15, 2013 Report Share Posted June 15, 2013 If one master holds just fine. How is 2 not going to? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 15, 2013 Report Share Posted June 15, 2013 If one master holds just fine. How is 2 not going to? QFMFT! Quote Link to comment Share on other sites More sharing options...
rubberneck Posted June 16, 2013 Report Share Posted June 16, 2013 Hey dweeb, I run two master links on our hillclimb bikes. IF properly installed, there's nothing wrong with two masters. Just curious but why? I mean i get it if you are a broke dick and cant afford a new chain. Arent you like a millionare off of the HQ monies alone? Quote Link to comment Share on other sites More sharing options...
3s1k Posted June 16, 2013 Author Report Share Posted June 16, 2013 From what I found from searching is guys use 2 links for quick gear ratio changes. Like changing sprockets I guess. Instead of needing more than one chain. Quote Link to comment Share on other sites More sharing options...
rubberneck Posted June 16, 2013 Report Share Posted June 16, 2013 $15,000 motor and cant afford a couple chains? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 16, 2013 Report Share Posted June 16, 2013 Hey dweeb, I run two master links on our hillclimb bikes. IF properly installed, there's nothing wrong with two masters. Just curious but why? I mean i get it if you are a broke dick and cant afford a new chain. Arent you like a millionare off of the HQ monies alone? Quick change gearing at the hillclimbs. I don't have time to be dicking around with chain breakers and shit. I have short pieces of chain already cut and ready to go. We've been running two masters since we started climbing back in 2005. You've seen the shit we do. If two masters will hold up to that, they will hold up to nearly anything. Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted June 16, 2013 Report Share Posted June 16, 2013 You also run the highest quality chain you can dummy. I really doubt this vato is going to run out and spend 200 bucks on a chain. IMO it is not a great idea with low quality chain but can be done. Again. Be sure the clip is on correctly. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 16, 2013 Report Share Posted June 16, 2013 You also run the highest quality chain you can dummy. I really doubt this vato is going to run out and spend 200 bucks on a chain. IMO it is not a great idea with low quality chain but can be done. Again. Be sure the clip is on correctly. I just run the 520 shit that Cam sells. Seems to be hold up well. Quote Link to comment Share on other sites More sharing options...
