joewest Posted June 15, 2013 Report Share Posted June 15, 2013 Banshee still won't start. I changed my reeds ( one of the pedals were broke) but it still wont start. Any ideas? I'm gonna clean the carbs Sunday. I really don't wanna pull them off again but I think Im gonna have too. Quote Link to comment Share on other sites More sharing options...
chevota84 Posted June 15, 2013 Report Share Posted June 15, 2013 Where did the petal go? Sent from my DROID RAZR HD using Xparent BlueTapatalk 2 Quote Link to comment Share on other sites More sharing options...
James_21 Posted June 15, 2013 Report Share Posted June 15, 2013 Good question^^^ you got spark? Gas turned on? Kill switch on run? Quote Link to comment Share on other sites More sharing options...
joewest Posted June 15, 2013 Author Report Share Posted June 15, 2013 No clue lol only about 1/8th of it was gone. I need to check for spark I changed the plugs. Gas is on. I have a push button kill switch Quote Link to comment Share on other sites More sharing options...
Young Guns Racing Posted June 15, 2013 Report Share Posted June 15, 2013 Check all ur basics first. Make sure gas is flowing into ur carbs. Check spark and check compression. If all is well and u want to see of ur carbs are flowing a little shot of carb cleaner or squirt of gas either in a plug hole or through the throat of the carbs and an attempt to start will let u know if you should look into ur carbs again. Let us know ur results. Quote Link to comment Share on other sites More sharing options...
joewest Posted June 15, 2013 Author Report Share Posted June 15, 2013 No spark. I pulled a plug and kicked it and there's not any spark. What could it be? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 15, 2013 Report Share Posted June 15, 2013 No spark. I pulled a plug and kicked it and there's not any spark. What could it be?I'm not being a dick, but FFS! Are you joking? What are you gonna do out in the trail/dune when your bike shuts off?? Pull out your phone and hope for enough reception and post a thread and ask what happened? Use your head! What have you checked so far? Are all the plugs connected? Is that push button good? Did you break a wire? Did you run a continuity test across the harness to see if there's a short/break you can't see? Did you check the coil,stator, plug caps? What did you do already to check? Not " my shit box broke, what happened?" Quote Link to comment Share on other sites More sharing options...
joewest Posted June 15, 2013 Author Report Share Posted June 15, 2013 I'm not being a dick, but FFS! Are you joking? What are you gonna do out in the trail/dune when your bike shuts off?? Pull out your phone and hope for enough reception and post a thread and ask what happened? Use your head! What have you checked so far? Are all the plugs connected? Is that push button good? Did you break a wire? Did you run a continuity test across the harness to see if there's a short/break you can't see? Did you check the coil,stator, plug caps? What did you do already to check? Not " my shit box broke, what happened?" Nope working on it as we speak. The plugs are connected. The kill switch was working fine its only a couple months old. How do I run a continuity test? Sorry I'm just asking for feedback while I work on it dude. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 15, 2013 Report Share Posted June 15, 2013 Get a clymers. Well first place I would be checking is around the air box and those plugs there. You replaced reeds so you were back there moving shit around. Dd you unplug the stator at all? How did the reeds break? When my reeds broke a bad backfire took them out from the harness melting to the exhaust. Quote Link to comment Share on other sites More sharing options...
joewest Posted June 15, 2013 Author Report Share Posted June 15, 2013 Fuck I'm being a dumbass this morning. It has spark I had the damn key off. I broke the reeds when I was off riding last weekend. It just started acting like it was running out of gas then just died and wouldn't even try to start. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 15, 2013 Report Share Posted June 15, 2013 Well good thing you got it figured out dummy Quote Link to comment Share on other sites More sharing options...
joewest Posted June 15, 2013 Author Report Share Posted June 15, 2013 It still won't start it just has spark. Quote Link to comment Share on other sites More sharing options...
James_21 Posted June 15, 2013 Report Share Posted June 15, 2013 So its got spark, are your carbs clean? Your gas turned on? Quote Link to comment Share on other sites More sharing options...
joewest Posted June 15, 2013 Author Report Share Posted June 15, 2013 Yes the gas is on. I cleaned the carbs not to long ago. Im gonna try to put a little gas in the cylinder and see if it trys to crank Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 15, 2013 Report Share Posted June 15, 2013 Is the thing so flooded from you kicking that the bottom end is just puddled with gas? Give it a real quick shot of starting fluid. See if it'll at least begin to crank. Quote Link to comment Share on other sites More sharing options...
