For sale: Yamaha Banshee 1987 4 mm stroker needs work
Contact information: PM me on here or e-mail me at korey.r.smith(at)gmail.com
Text or call at two 6 zero - 3 0 TWO - 6 four 1 four
Price: $1800 o.b.o.
Item Description:
Vito’s Performance 4 mm stroker crank and spacer plate
Weisco forged pistons .60 over
Toomey T-5 steel pipes painted black
Toomey Hush kit 3.0 with Spark Arrestor
Boyesen Rad Valves
White Brother’s boost bottle
Individual Uni foam Air filters with prefilters
Ricky Stator high performance stator with adjustable timing plate
RAD Manufacturing Billet Aluminum Twin row bearing carrier
G-Force adjustable width racing axle (nice wide stance)
Ohlins Adjustable Gas Shocks (fronts only)
Douglas polished aluminum rims
Razr front tires (less than two years old)
Shredder rear tires
Full body skid plate and a-arm skid plates
All stainless steel allen bolts
All bearings, seals, and gaskets replaced 2 years ago
CEET graphics
Fly Polished Aluminum handle bars with gel grips
I just went riding this weekend and noticed there was an issue the motor. taking a top end of revealed that the shifter side cylinder head cracked the skirt. Upon further inspection of the sooner I noticed that the damage was not all that significant. I'm done with this four wheeler and no longer want to work on this my loss is your gain. I have no interest in fixing this. I will throw all additional gaskets, carb parts, j and lower a arms, and anything else I have. The cylinders will need honed and new pistons and rings will need to be purchased. The crank rotates freely however I would recommend splitting the cases to clean out any additional material that is in there. Transimission is in great shape as well as the clutch. This can go to a new home. I will post additional pictures of the damage tomorrow.
The bike looks clean. Have you listed it locally on CL. If you do that for $1,500 it should sell quick.
Like others have said if you were in my area I would scoop it right up.
Good luck
Troy
