New Lectrons
neeper2
Pull the choke!
The power jet will only pull fuel around WOT.
Make sure you have the metering rod set corectly also. I have a single 38/40 on mine and the starting point is 2" from tip of rod to the bottom of the slide.
Set rod at a point that will allow the motor to start and idle. Then adjust rod until you get a good crisp throttle responce. After you get the idle and mid dialed in do you go to selecting you power jet size.
If you need more tech info give fastbygast a call. They are super cool and will set you on the right track.
Cheers
Astromybud
