cunninghambc Posted June 6, 2013 Report Share Posted June 6, 2013 34 mm pwk ported 350cc stator side is blowing milky stuff out the pipe and hardly running can this be caused of being to rich or is there water getting in that cylinder?? Quote Link to comment Share on other sites More sharing options...
Wheelman Chassis Posted June 6, 2013 Report Share Posted June 6, 2013 Probly that carb super rich, swap the carbs side to side and see if it follows. check your float height in that carb also. Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted June 6, 2013 Report Share Posted June 6, 2013 I would recommend doing a cooling system pressure test. Is the bike using coolant? Is it preasurizing the cooling system? White milky spray isn't normal, and would be a sign of a coolant leak. Quote Link to comment Share on other sites More sharing options...
Finch Posted June 6, 2013 Report Share Posted June 6, 2013 X2 ^ if ya dont have a tester and havnt checked your coolant in awhile. I'd give that a peak. If it is coolant I wouldn't keep starting it as for risk of to much getting in there and hydro locking the motor. Quote Link to comment Share on other sites More sharing options...
Wheelman Chassis Posted June 6, 2013 Report Share Posted June 6, 2013 raw fuel out the pipe wil also have a white ish color when it gets contaminated with air.. Quote Link to comment Share on other sites More sharing options...
