sheerider11 Posted June 6, 2013 Report Share Posted June 6, 2013 I have the basic fox floats, and I'm looking at where I should be for a good base point to start to set them up for me. I have +2+1 I weigh at 195 about bike gassed and gear on I'm riding in extremely whooped out NJ sand pits. I hammer through the whoops in 4th or 5th floating the front end as much as possible So I got the shocks used and have no info on them. Quote Link to comment Share on other sites More sharing options...
04zSpittinKlotz Posted June 6, 2013 Report Share Posted June 6, 2013 Im 155ish and liked them on the soft side, I think I ran 55psi... dont remember exactly. with your weight, Id say just start around 75 and go from there. You will have to play with them a bit to find the ride you like. The air shocks are progressive so you dont really have to worry about bottoming out. (unless you run them with no air.. also the pressure will change with temp differences so check them kind of often. GREAT SHOCKS !!! Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 6, 2013 Author Report Share Posted June 6, 2013 Now with that temp change, do these shocks heat up a lot? I've gotten my works to where I touched them and it was really hot and kind of burned. Quote Link to comment Share on other sites More sharing options...
04zSpittinKlotz Posted June 6, 2013 Report Share Posted June 6, 2013 Honestly im not sure on that one... i never really thought to check them after riding Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted June 6, 2013 Report Share Posted June 6, 2013 If your works shocks got too hot to touch, something was wrong with them. I've cycled works steelers on the dyno for 2 hours at 90 strokes per minute and only increased external temperature by ~40 degrees. As far as the air expansion, there is no easy way to explain it. It is a very sophisticated algebraic equation to compute the volumetric expansion coefficient. The chemical make-up of the air in your specific region will vary, and the expansion rate will differ. Basically, fuck around with it and see what it does. Quote Link to comment Share on other sites More sharing options...
10milmike Posted June 6, 2013 Report Share Posted June 6, 2013 I am fat and i run mine at 60 psi. Quote Link to comment Share on other sites More sharing options...
04zSpittinKlotz Posted June 6, 2013 Report Share Posted June 6, 2013 There ya go ^.... x2 Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted June 6, 2013 Report Share Posted June 6, 2013 I'm 150 and I ran mine at 70psi. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 6, 2013 Author Report Share Posted June 6, 2013 Yeah the works were pieces of shit. So it looks like I'll be going around 60-70 psi. Thanks Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted June 6, 2013 Report Share Posted June 6, 2013 when you check/add/remove air, do it with the wheels off the ground. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 6, 2013 Author Report Share Posted June 6, 2013 when you check/add/remove air, do it with the wheels off the ground.That's kind of a pain in the ass. How do people do it in the dunes by themselves? Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted June 6, 2013 Report Share Posted June 6, 2013 macgyver something. Quote Link to comment Share on other sites More sharing options...
nastyracing Posted June 7, 2013 Report Share Posted June 7, 2013 Don't forget ur Lil penis pump when we out there riding axis ftw! Ahaha 1 Quote Link to comment Share on other sites More sharing options...
Sledneckwaylan Posted July 15, 2013 Report Share Posted July 15, 2013 Im going to give you a piece of advice, the best thing you can do (the best thing ive done with fox floats) is to go buy the evol upgrade kit for them. Around $450 for 2 shocks. It turns it into a 2 stage shock, and holy hell does it make a massive difference, especially if you like hitting jumps, or ride on rough bumpy terain. Set the initial stage real soft, About 45-60 depending how much you weigh, and your preference, and the second stage firmer. Its a simple concept, and works great. The initial stage gives you a soft smooth impact, but the second stage keeps you from bottoming out or loosing control. Quote Link to comment Share on other sites More sharing options...
Buffalo-Banshee Posted July 16, 2013 Report Share Posted July 16, 2013 I found that 90 psi has worked the best for me but I weigh 225. You just need to bring your pump and mess with them. Quote Link to comment Share on other sites More sharing options...
