bogging and starting problem.
I was out riding earlier and my quad started bogging Like the filter was really dirty and then it died and took forever to start. When it did it ran fine then about a min after I was going it started bogging and finally died then wouldn't start..... any ideas? I think I might of gotten my filter wet but I'm not sure if that would make it do that. Im home now and took the filter off cleaned it etc. I'm letting it dry right now. I also changed the plugs and dida compression check both cylinders are a little over 110 psi. Any ideas???
out of gas? fuel shut off? fuel cap vent plugged?
Easy way to tell if the carb floats are stuck is to open the bowl drains and see if it continues to drain.  If it stops....try to tap the carb with the butt of a screw driver.
Then get back to us.
