Crank Choices
Well, most cranks are good, but if you want a performance one Andy at grand river racing can put together a nice one. He can add 10 ball bearings to the one you have and put a needle bearing on the pto side. I believe some others build them that way too. A little $$$, but may be worth it. I just spun a 7 ball bearing after 3 years. I don't think it should have done that. It's a wiseco hot rod crank.
If you want a reliable, not too expensive, and all out explosive horsepower situation, by all means go with the +4 long rod Wiseco and have it ported specifically for that crank...it will just blow your mind...Jim
Jim, thats the crank going in my motor isnt it?.....can you take some pics of my build? id like to see your 12 port design, before you button it up.......
www.bansheesuperstore.com check em' out. TDR (tony doukas racing) i got a High performance ten ball bearing main, trued and welded, fully rebuildable inner webs and hot rods connecting rods crankshaft with THE WORKS for tatatatatat (drum roll) for 350.00 bucks out the door, Best price going for the best stuff around it can handle anyting you throw at it :D
Hey stomp yeah you got that crank from TDR for 350 but , its a rebuilt crank not new and it is not a stroker crank he sells his stroker for $1000 Drum roll please ............... wiseco hot rod crank for 400-500 bucks almost anywhere I got mine fore 400 trued welded and BRAND new 4mm stroker
  • 2 weeks later...
