Ayesully810 Posted September 18, 2017 Report Share Posted September 18, 2017 As stated above. Bench testing wont always shift through all gears perfect it needs to be running i ran into the same issue. Set your eccentric screw right and lock it down. As long as all is done right inside it should be fineSent from my LGMS210 using Tapatalk Quote Link to comment Share on other sites More sharing options...
