ben-driscoll Posted May 31, 2013 Report Share Posted May 31, 2013 what so you guys think someone should be running for sproket size if you had a 2-5 trans running a 300 ft strip with a 365 drag ported with override trans. Quote Link to comment Share on other sites More sharing options...
rg97 Posted May 31, 2013 Report Share Posted May 31, 2013 depends if you want accel or top speed. for 300ft drags, i'd go with 15 front or maybe a 16 (for more speed, less torque) and 39 or 40 rear Quote Link to comment Share on other sites More sharing options...
possum Posted May 31, 2013 Report Share Posted May 31, 2013 tire rollout, rider weight, swingarm and fuel play a role. Quote Link to comment Share on other sites More sharing options...
ben-driscoll Posted June 1, 2013 Author Report Share Posted June 1, 2013 22" tire, 190 lb rider, stock legth swinger, and running 93 and 110 mixed together gas, motor is runing at 150 psi compression Quote Link to comment Share on other sites More sharing options...
m671054 Posted June 1, 2013 Report Share Posted June 1, 2013 Dirt,sand,asphalt? whats traction like? what you got now? Quote Link to comment Share on other sites More sharing options...
ben-driscoll Posted June 1, 2013 Author Report Share Posted June 1, 2013 dirt, hard semi-hard track Quote Link to comment Share on other sites More sharing options...
m671054 Posted June 1, 2013 Report Share Posted June 1, 2013 If your anticipating wheel spin try 16-41 Quote Link to comment Share on other sites More sharing options...
ben-driscoll Posted June 2, 2013 Author Report Share Posted June 2, 2013 right now im running 13-41 and it runs good but i think im starting to run outta gear Quote Link to comment Share on other sites More sharing options...
04_blu_shee Posted June 2, 2013 Report Share Posted June 2, 2013 13-41 that would be gearing for Motocross...with your motor and rider weight you could easily run 15-40 gear...put a swinger on that Bitch with some aggressive paddles and let it eat Quote Link to comment Share on other sites More sharing options...
ben-driscoll Posted June 4, 2013 Author Report Share Posted June 4, 2013 i got a stock length swinger with a aluminum axle but running a good wheelie bar Quote Link to comment Share on other sites More sharing options...
possum Posted June 4, 2013 Report Share Posted June 4, 2013 well what gearing have you tried. And what happen? Quote Link to comment Share on other sites More sharing options...
