Derrickc14 Posted May 30, 2013 Report Share Posted May 30, 2013 I have a 02 banchee with toomy t5's, k&n filter in box - lid/cover off and v force II reeds. Baught it off someone and i just want to do some maintenance before i ride her. I live in pa-sealevel. I need main jet size recomandations for the mods that are on it. Any help for the newbee?. first banshee ever. I did reseach for the past 3days and found some insite on jet sizes that people are running but their mods exceed mine by a long shot. thanks for you Help Quote Link to comment Share on other sites More sharing options...
tdod101 Posted May 30, 2013 Report Share Posted May 30, 2013 240 - 260 main 25 pilot Needle middle clip A/S 1.5 turns out Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 30, 2013 Report Share Posted May 30, 2013 240 - 260 main 25 pilot Needle middle clip A/S 1.5 turns out Way to lean for here. 27.5 260-280. I'm in jersey so I'm pretty close to where your at Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted May 30, 2013 Report Share Posted May 30, 2013 Toomey sells a different needle for there pipes I would recommend picking a set up... Probably start with a 300 main and do plug chops and lean it down slowly Quote Link to comment Share on other sites More sharing options...
Derrickc14 Posted May 30, 2013 Author Report Share Posted May 30, 2013 Thanks boys! Huge help. I will try sheeriders first since hes so close to me. Thank you again Sheerider - what kit should I buy and where? Quote Link to comment Share on other sites More sharing options...
SpecialEd 05 Posted May 31, 2013 Report Share Posted May 31, 2013 If you're running no lid and K&N anything under 280 will be too lean. I'd be at a safe 320, seems to be the average size for lid off with 27.5 pilots at 1.5 turns out. With the V-Force reeds you should be dropping the needles 1 clip (leaner). If you have the Toomey needles (6 groove) you should be at the 4th groove from the tapered end. Here is a handy jetting guide. If you scroll to the bottom there is a list of mods where can add up the jet sizes from the mods you have to get a ball park idea of where to start. http://www.dfn.com/agservices/jetfaq.html Quote Link to comment Share on other sites More sharing options...
