bansheegoon Posted May 28, 2013 Report Share Posted May 28, 2013 There seems to be play side to side and the fingers came off the star and got bunched up. Figured that out but why is there play is there supposed to be a c clip on the shift lever side or just snug the lever up to the stator cover. Thanks Quote Link to comment Share on other sites More sharing options...
robert0762 Posted May 28, 2013 Report Share Posted May 28, 2013 Shift star claw is jammed or cocked Quote Link to comment Share on other sites More sharing options...
bansheegoon Posted May 29, 2013 Author Report Share Posted May 29, 2013 Because the shaft with the claw moves side to side. Trying to figure out if the lever is supposed to snug to the stator cover or am I missing a c clip or something Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted May 29, 2013 Report Share Posted May 29, 2013 The white bushing (pink arrow) hit the case and the end of the shaft (blue arrow) hit the cover. You can use a straight edge across the opening with the cover off to check it. Make sure the pawl isn't sloppy on the pivot. Quote Link to comment Share on other sites More sharing options...
