slingshot w/ pancake bearing?
375hp banshees
Some of the pancake bearing set ups aren't as adjustable. Mine, I have to pull the outer plate off and adjust the pancake put it back in. Slap the cover on. It's a fast process now but the first couple times were guess and check.
thats what i did (w/ the eng out) was hoping not to have to do it that way later
I don't think that wrench would do it for mine
my slingshot says "slingshot  gigot engineering...
it also has 2 screws that hold the plate on when you take it off.
there are extended bearing pushers around for lockups, and the such.  i just happen to know a dude that has a bunch ( some are even 4140 steel!)
  • 4 weeks later...
What pointers do u have to line up when putting clutch together? My basket and such are stock besides the friction plates and the steals.. I cant seem to get my clutch right so im wondering if im doing something wrong
On the opposite side of the case by the drive sprocket. If you have a good whacked case, you may not have an arrow
