i have a 2001 banshee built to go fast, has a cub motor with a hot rods stroker crank, o ring stock head ,small bore cpi out of frame drag pipes , the bike has a 1 tru 4 override with neutral down dunnable , 39 mm mukunis ,new vforce 4 ,9 plate clutch to hold all that power,aluminum radiator, drag bars , rear +2 -2 axle , drag rims on front and 10 inch on rear , right now the bike is sitting on front blaster suspension , i have all the home made struts to make it rigid, the bike makes crazy power , this is a fresh motor that is running on 110 gas  ,this bike has a clean tittle under my name ,i will include lots of extra parts like a oem front rims, oem rear plastics ,etc , if you know about banshees you know how much money this bike has on parts only  , 3053087112 . for pics go to   http://miami.craigslist.org/mdc/mcy/3832176605.html thanks
