noonansar Posted May 22, 2013 Report Share Posted May 22, 2013 Are you sure that your jetting is spot on? Quote Link to comment Share on other sites More sharing options...
tdod101 Posted May 22, 2013 Author Report Share Posted May 22, 2013 Are you sure that your jetting is spot on? Definetly! Quote Link to comment Share on other sites More sharing options...
oldskool Posted May 22, 2013 Report Share Posted May 22, 2013 early shee's had a stock 13t front sprocket, later they went to a 14T stock. Do like said and put a 15t on, your gonna see a signifigcant difference, maybe even some 22"tires. set floats to spec to make sure you got enough fuel supply to run out 6th gear. Quote Link to comment Share on other sites More sharing options...
joey83 Posted May 23, 2013 Report Share Posted May 23, 2013 How tall are your rear tires????? Just save up some cash. Go fast = $ And if you havent, mod your stock timing plate for 4° advance. Its the only free mod I know besides learning to ride better, more tire pressure(can hurt your take off), and cheap mods like going to a 15 front sprocket. How do you know your jetting is right? What is your jetting and elevation? Good luck Quote Link to comment Share on other sites More sharing options...
rg97 Posted May 23, 2013 Report Share Posted May 23, 2013 X2^^^^ You never said what tires you're running. they make a big difference too. Running something like a 18" will let you wheelie all you want (becasue of the better torque/accel) but a 22" on the other hand will give less torque but you'll top out way higher. For my '97 shee the stock sprockets are 14/41, howd you end up with a 13/40 (i think thats what you said)? Remember too that engine mods wont make your engine spin higher RPM's (more speed), or at most a very little higher. Engine mods will change how long it takes to get to that speed. Im run a stock ratio with bald 20" (measure in at 19") and i get to 70. Change your ratio, you'll really notice it. Quote Link to comment Share on other sites More sharing options...
rg97 Posted May 23, 2013 Report Share Posted May 23, 2013 How tall are your rear tires????? Just save up some cash. Go fast = $ And if you havent, mod your stock timing plate for 4° advance. Its the only free mod I know besides learning to ride better, more tire pressure(can hurt your take off), and cheap mods like going to a 15 front sprocket. How do you know your jetting is right? What is your jetting and elevation? Good luck you beat me to posting that comment about tires > lol Quote Link to comment Share on other sites More sharing options...
rg97 Posted May 23, 2013 Report Share Posted May 23, 2013 Get a new powerband (i like the red ones with a black stripe) and a boost bottle. youll be pushing 90!! Quote Link to comment Share on other sites More sharing options...
twittle Posted May 23, 2013 Report Share Posted May 23, 2013 If your buddy wont even tell you about his secret tranny how do you know he's also not telling you about his secret porting, milled head, advanced timing or whatever other internal mods you can't see. Just saying.... Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted May 23, 2013 Report Share Posted May 23, 2013 Always get an AIDS test before going faster.... 1 Quote Link to comment Share on other sites More sharing options...
tdod101 Posted May 23, 2013 Author Report Share Posted May 23, 2013 X2^^^^ You never said what tires you're running. they make a big difference too. Running something like a 18" will let you wheelie all you want (becasue of the better torque/accel) but a 22" on the other hand will give less torque but you'll top out way higher. For my '97 shee the stock sprockets are 14/41, howd you end up with a 13/40 (i think thats what you said)? Remember too that engine mods wont make your engine spin higher RPM's (more speed), or at most a very little higher. Engine mods will change how long it takes to get to that speed. Im run a stock ratio with bald 20" (measure in at 19") and i get to 70. Change your ratio, you'll really notice it. Tires are 22 x 12.5 - 9 Rims are 9 x 8.5 AT Quote Link to comment Share on other sites More sharing options...
