Right Cylinder goes in and out
just put together my buddies bike
4mil dune port blaster angle 18cc domes
shearers
stock carbs 25 pilot 350 main uni filters
sea level +4 timing
bike runs fine (a lil rich) until 6th gear when right side dies
I kill the bike and start back up and it comes back
thought I was running the bowl dry but when I pull the plug they are wet
so thought maybe I was soaking the plug leaned out the needle until I was visibly lean same outcome.
I swapped cdi box and also tried swapping around plug wires and tried new plug caps
set gap on flywheel insanely close same outcome both sides have good compression. Topend is new
Crossover tube is installed in between carbs
Any ideas?
Hmmm, a 25 pilot does not sound right at all. My girlfriends is a 27.5 280 on a SS trail port with fmf and k&n at sea level.
what are the plug gaps at? What's each side of the coil ohm at? Could be a bad coil favoring the least resistant path. Some how I got a B8es and a b8ers in the same bike, resistor plug wouldn't fire. Just something to look at.
