Debolt Posted May 20, 2013 Report Share Posted May 20, 2013 I have 2 banshee 1 was a project with no spark and it has a bad top end and was heavily modified the other was a brand new only run 3 or 4 weeks then crashed off a hill climb known as suicide! Both a-arms are bent (upper)and maybe lower the rear axle is bent for sure don't know I fame is bent or how bad how can I check it or should I just use the other frame? Any help would be great thanks Quote Link to comment Share on other sites More sharing options...
Finch Posted May 20, 2013 Report Share Posted May 20, 2013 how many times ya gonna keep posting this? Quote Link to comment Share on other sites More sharing options...
fappy'97 Posted May 20, 2013 Report Share Posted May 20, 2013 87. Quote Link to comment Share on other sites More sharing options...
noonansar Posted May 20, 2013 Report Share Posted May 20, 2013 Should be pretty obvious if it is bent. Look for cracked paint around weld areas, where tubes come together, and near factory bends. Another obvious sign is if good straight parts don't easily fit or bolt holes don't line up. Just inspect the frame and use common sense. There is a good chance that it is tweaked, and they do not straighten easy. Quote Link to comment Share on other sites More sharing options...
m671054 Posted May 21, 2013 Report Share Posted May 21, 2013 If both arms and axle bent for sure the frame is bent at the subframe and the steering stem hoop. Only thing its good for is cutting up for a drag chassis Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted May 21, 2013 Report Share Posted May 21, 2013 swap all the bent parts out from the bent one and swap in the straight parts from the dead one, if it doesnt look right swap EVERYTHING over to the straight frame and ride the tits off it..you could do it in one day Quote Link to comment Share on other sites More sharing options...
registered user Posted May 21, 2013 Report Share Posted May 21, 2013 uh ya quit posting nonsense. go switch frames and be done Quote Link to comment Share on other sites More sharing options...
Debolt Posted May 22, 2013 Author Report Share Posted May 22, 2013 Thanks for the info hope to start swapping parts this weekend Quote Link to comment Share on other sites More sharing options...
Debolt Posted September 23, 2013 Author Report Share Posted September 23, 2013 Finally got them together and damn its fast thank god for two stroke bikes Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted September 23, 2013 Report Share Posted September 23, 2013 only took 4 months? Quote Link to comment Share on other sites More sharing options...
Debolt Posted November 24, 2013 Author Report Share Posted November 24, 2013 Yea been busy working but worth the wait Quote Link to comment Share on other sites More sharing options...
