Bennett69 Posted May 18, 2013 Report Share Posted May 18, 2013 Thinking about running 100LL fuel ?? Quote Link to comment Share on other sites More sharing options...
Finch Posted May 18, 2013 Report Share Posted May 18, 2013 why? Quote Link to comment Share on other sites More sharing options...
Bennett69 Posted May 18, 2013 Author Report Share Posted May 18, 2013 higher octane level more responsive ?? Quote Link to comment Share on other sites More sharing options...
bansheegoon Posted May 18, 2013 Report Share Posted May 18, 2013 Higher octane doesn't mean more responsive. There have been lots of threads about this recently Quote Link to comment Share on other sites More sharing options...
Bennett69 Posted May 18, 2013 Author Report Share Posted May 18, 2013 ill have to look back and check them out Quote Link to comment Share on other sites More sharing options...
Bennett69 Posted May 18, 2013 Author Report Share Posted May 18, 2013 so is there any down side to running 100LL Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 18, 2013 Report Share Posted May 18, 2013 so is there any down side to running 100LLYou can't go to any gas station and get it Quote Link to comment Share on other sites More sharing options...
Bennett69 Posted May 18, 2013 Author Report Share Posted May 18, 2013 is that the only downside ?? Quote Link to comment Share on other sites More sharing options...
Finch Posted May 18, 2013 Report Share Posted May 18, 2013 a waste if ya dont need it Quote Link to comment Share on other sites More sharing options...
Buckwheat Posted May 18, 2013 Report Share Posted May 18, 2013 It has a much shorter shelf life than automotive gasoline. It smells good burning though! Quote Link to comment Share on other sites More sharing options...
ginger Posted May 18, 2013 Report Share Posted May 18, 2013 It has a much longer shelf life. It has no ethanol which kills the life of gas. I run it because I'm borderline to much compression for 93. The builder said I would be better off running it. Sent from my DROID RAZR using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
chevota84 Posted May 18, 2013 Report Share Posted May 18, 2013 It has a much longer shelf life. It has no ethanol which kills the life of gas. I run it because I'm borderline to much compression for 93. The builder said I would be better off running it. Sent from my DROID RAZR using Tapatalk 2 Exactly! I run most of my small engines on 100ll and have zero carb issues when I need them again. It'll tune leaner than race or pump gas because its oxygenated and it seems to not mix well with bean oil in my experience. Sent from my DROID RAZR HD using Xparent BlueTapatalk 2 Quote Link to comment Share on other sites More sharing options...
Buckwheat Posted May 18, 2013 Report Share Posted May 18, 2013 It has a much longer shelf life. It has no ethanol which kills the life of gas. I run it because I'm borderline to much compression for 93. The builder said I would be better off running it. Sent from my DROID RAZR using Tapatalk 2 It didn't in my case. Went bad in under two months. Quote Link to comment Share on other sites More sharing options...
registered user Posted May 18, 2013 Report Share Posted May 18, 2013 ive always used vp or sunoco. but from what i read avgas works decent if you cut it down 50% with 91. ive never seen anybody recomend running it straight up and some sources say avoid it all together. aparently it burns extremely slow Quote Link to comment Share on other sites More sharing options...
pabansheematt Posted May 18, 2013 Report Share Posted May 18, 2013 I tried it in my Cheetah years ago because I had easy access to it. ( my boss owns a airport ) But it ran like shit? Don't know why, but it didn't work for me. Quote Link to comment Share on other sites More sharing options...
