nitrocircus Posted May 18, 2013 Report Share Posted May 18, 2013 alright i just finnished my banshee and i cant get it started. it has spark and fresh top and bottom end. i kicked this thing till i had a hole in my shoe it would fire like once but not start and a loud backfire every once in a wyle. any ideas? and after kicking it for so long the plugs still looked dry maybe not getting fuel? i know the carbs are full of gas becouse i can see the level in the dial a jet tubes. Quote Link to comment Share on other sites More sharing options...
fappy'97 Posted May 18, 2013 Report Share Posted May 18, 2013 What kind of stator? Quote Link to comment Share on other sites More sharing options...
nitrocircus Posted May 18, 2013 Author Report Share Posted May 18, 2013 RM stator but is has real strong spark and its set at +3 Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 18, 2013 Report Share Posted May 18, 2013 Good flywheel? Is it on straight? The woodruff didn't get knocked out or forgot? Pick up gap? Try to get a oem stator on there if you can Quote Link to comment Share on other sites More sharing options...
nitrocircus Posted May 18, 2013 Author Report Share Posted May 18, 2013 wouldnt this all be good if i have good spark? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 18, 2013 Report Share Posted May 18, 2013 Yep. Must be fine. Prob just tire pressure, stupid me. Quote Link to comment Share on other sites More sharing options...
Finch Posted May 18, 2013 Report Share Posted May 18, 2013 not for sure. sure yoru floats are not sticking? that can happen if they sat dry for a bit. make sure every thing is pluged in also and good ground to the frame Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted May 18, 2013 Report Share Posted May 18, 2013 Yep. Must be fine. Prob just tire pressure, stupid me. I was going to suggest that the rear spring preload needed to be adjusted, but I only know suspension stuff. 1 Quote Link to comment Share on other sites More sharing options...
nitrocircus Posted May 18, 2013 Author Report Share Posted May 18, 2013 Yep. Must be fine. Prob just tire pressure, stupid me. lol, ya i checked the tire pressure, that was my first guess. maybe i could check if all my stickers are in the right place also. Quote Link to comment Share on other sites More sharing options...
nitrocircus Posted May 18, 2013 Author Report Share Posted May 18, 2013 i think it is not getting fuel in the engine. could this be my floats being out of wack? i know there is gas in the carbs but my plugs are dry? i have 34mm pwk's Quote Link to comment Share on other sites More sharing options...
nitrocircus Posted May 18, 2013 Author Report Share Posted May 18, 2013 not for sure. sure yoru floats are not sticking? that can happen if they sat dry for a bit. make sure every thing is pluged in also and good ground to the frame what grounds to the frame? Quote Link to comment Share on other sites More sharing options...
twittle Posted May 19, 2013 Report Share Posted May 19, 2013 Check that your slides are down all the way.I just had the same thing happen to me. New build with 35 pwk's from another bike I never ran, plugs looked dry also. Somebody adjusted the carb tops so the slides were still open about 1/4" all the time. Didn't even check that at first because they were supposed to be off a running bike with almost the exact same setup. Quote Link to comment Share on other sites More sharing options...
registered user Posted May 19, 2013 Report Share Posted May 19, 2013 if plugs are dry thats your first clue Quote Link to comment Share on other sites More sharing options...
troyzstang Posted May 19, 2013 Report Share Posted May 19, 2013 Check that your slides are down all the way.I just had the same thing happen to me. New build with 35 pwk's from another bike I never ran, plugs looked dry also. Somebody adjusted the carb tops so the slides were still open about 1/4" all the time. Didn't even check that at first because they were supposed to be off a running bike with almost the exact same setup. Had the same issue too. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted May 19, 2013 Report Share Posted May 19, 2013 I'm going with pilot is way to small if there keihin pj carbs I have seen them end up at 62 pilots more than a few times,seemed odd but it has happened to me more than 6 times,plus all the mx trail set ups that run them end up at 162-168 main and big pilots Quote Link to comment Share on other sites More sharing options...
