4mil89 Posted May 17, 2013 Report Share Posted May 17, 2013 4mil long rod Wiseco 795 64.50mm Stock modded cages with boyessen dual stage Graydon proline inframe drags Stock cylinder with passion racing 12 port (aggressive trail) Pwk 28s bored to 30mm 160 main 50 pilot Jjh needle Sealevel-500ft I started jetting this and its pretty close i first set the needle position in the middle and it had a hard time pulling out and you had to pretty much rev it up and dump it to get it moving. I tried moving the clip up (dropping the needle) and it only got worse. I then moved the clip down (raised the needle) all the way up and its alot better but its still a littlr off. Airscrews are 1,5 out. Should i jump up a size with the pilot? Lmk if you need any more info Kevin Sent from my SAMSUNG-SGH-I717 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted May 17, 2013 Report Share Posted May 17, 2013 Ive always liked (had better luck) using the N68A Needles better than the JJH, when i ran those sized carbs. Anyways, Do you have a couple 48's on hand to try? Quote Link to comment Share on other sites More sharing options...
ginger Posted May 17, 2013 Report Share Posted May 17, 2013 your main should be close to spot on. i would put 48 pilots in. i found now that its hotter, i have to lean my pilots on a similar setup and elevation Quote Link to comment Share on other sites More sharing options...
4mil89 Posted May 19, 2013 Author Report Share Posted May 19, 2013 hmm i jumped up to 52 and started dropping the needle. im back to the middle clip position and it seems good except its a little boggy on the low end and if i start a pull from low rpms and give it wot it like "purrs" or "breaks up" for about 1/2 second before it hits power band and then it rips... Quote Link to comment Share on other sites More sharing options...
special06shee Posted May 19, 2013 Report Share Posted May 19, 2013 If your having a ton of problem with jetting maybe try another needle. Go on sudco web site and study their needle chart. Also in my experience sometimes jetting is not the issue when it comes to a smooth power delivery. If you have an improper or a poor dome design that could be the issue as well. Im not saying that this is your issue but from my experience a properly set motor(dome design) it seems to me that jetting is not as crucial when it comes to a smooth power transition. But then again, this is jmo. Quote Link to comment Share on other sites More sharing options...
4mil89 Posted May 20, 2013 Author Report Share Posted May 20, 2013 Special....im running a stock head...call me i know your from my area 7178264197 ill compensate you if ypu can help! Sent from my SAMSUNG-SGH-I717 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
special06shee Posted May 20, 2013 Report Share Posted May 20, 2013 Lol! Im easy, just not cheap. Quote Link to comment Share on other sites More sharing options...
4mil89 Posted May 20, 2013 Author Report Share Posted May 20, 2013 Im sure we could work something out...lmk what your thinking Kevin Sent from my SAMSUNG-SGH-I717 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
