couple of question?
fourjs
Where can I purchase just the carb needle (5n7) for a stock carb?
And the manual states that the float bowl height is 20-22mm, so if i set it at 24-26mm, this is lowering the amount of fuel in the bowl, correct?
Juat making sure that i am reading the manual correctly.
Thanks...
Yes on the float height. If its a larger measurement, less fuel and vise verse. Check WITHOUT the gasket in place.
Ask on here for that needle, im sure someone has one kicking around. If not try a local shop, then call some sponsors here for one.
