Chain size
No, one link is one side plate so every two pins is one link. I don't use chain breakers anymore as I found that the the pins would leave marks inside the link barrels as it is pushes through. Instead I just grind the end of the pins down with an angle grinder going half way through the link plate. The link pins will just fall out then.
Ok great thanks, I'm gonna use the chain breaker on the old one just to see how it works, if I don't like it ill try your way
