two smoker Posted May 13, 2013 Report Share Posted May 13, 2013 OK my right side keeps killing plug ride it for 5 min and its dead any ideas Quote Link to comment Share on other sites More sharing options...
tdod101 Posted May 13, 2013 Report Share Posted May 13, 2013 Try a new boot at first, cheap and easy, I get the Ngk red boots Quote Link to comment Share on other sites More sharing options...
two smoker Posted May 13, 2013 Author Report Share Posted May 13, 2013 At idol it will spark for a min than give it gas and kills plug Quote Link to comment Share on other sites More sharing options...
tdod101 Posted May 13, 2013 Report Share Posted May 13, 2013 Probably a bad boot dude, or even the wires from the CDI, chop a bit off put new boots on, and check your motor to frame ground wire as well, easy start Quote Link to comment Share on other sites More sharing options...
coryv4 Posted May 13, 2013 Report Share Posted May 13, 2013 right side crank seal or reed or low comp, we need more details here. Quote Link to comment Share on other sites More sharing options...
tdod101 Posted May 13, 2013 Report Share Posted May 13, 2013 With electrical it's just a process of elimination, keep it simple Quote Link to comment Share on other sites More sharing options...
two smoker Posted May 13, 2013 Author Report Share Posted May 13, 2013 120 psi both sides pulled carb reeds are good Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted May 13, 2013 Report Share Posted May 13, 2013 Parking brake assembly still installed? Quote Link to comment Share on other sites More sharing options...
two smoker Posted May 13, 2013 Author Report Share Posted May 13, 2013 OK changed caps no longer kills plug now will fire right at idol but cuts out when u rev it up Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted May 13, 2013 Report Share Posted May 13, 2013 Parking brake assembly still installed? ^ ????? Quote Link to comment Share on other sites More sharing options...
two smoker Posted May 13, 2013 Author Report Share Posted May 13, 2013 No park break Quote Link to comment Share on other sites More sharing options...
tdod101 Posted May 14, 2013 Report Share Posted May 14, 2013 OK changed caps no longer kills plug now will fire right at idol but cuts out when u rev it up Ok good, step one done, try new plugs, just go BR9ES, than make sure your ground wire I connected properly and has good contact Quote Link to comment Share on other sites More sharing options...
two smoker Posted May 14, 2013 Author Report Share Posted May 14, 2013 Ya did it Quote Link to comment Share on other sites More sharing options...
two smoker Posted May 14, 2013 Author Report Share Posted May 14, 2013 Its also back fires sometimes now when I kick it hasn't done that befor Quote Link to comment Share on other sites More sharing options...
tdod101 Posted May 14, 2013 Report Share Posted May 14, 2013 Hmm, clean your carbs, I whats your jetting like ? What are your mods ? What kind of fuel ratio are you using, list as much info as you can Quote Link to comment Share on other sites More sharing options...
