Grey Posted May 13, 2013 Report Share Posted May 13, 2013 Brand new tensioner I had laying around. I put it on, but It didn't work out for my needs. Has minor scratches from being put together and mounted, but a chain has never rolled on it. $60 Shipped. Grey 702-427-8608 Quote Link to comment Share on other sites More sharing options...
tdod101 Posted May 20, 2013 Report Share Posted May 20, 2013 How does it work? I've never seen one Quote Link to comment Share on other sites More sharing options...
Nieskes Posted May 20, 2013 Report Share Posted May 20, 2013 Cant ya see the picture in the background? Quote Link to comment Share on other sites More sharing options...
Grey Posted May 20, 2013 Author Report Share Posted May 20, 2013 Badically keeps Tension on the chain via a spring mechanism...... Quote Link to comment Share on other sites More sharing options...
tdod101 Posted May 20, 2013 Report Share Posted May 20, 2013 Ah so no need for the bolt tensioners at the back of the carrier ? Quote Link to comment Share on other sites More sharing options...
tdod101 Posted May 20, 2013 Report Share Posted May 20, 2013 Pm sent Quote Link to comment Share on other sites More sharing options...
possum Posted May 20, 2013 Report Share Posted May 20, 2013 Retard. Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted May 20, 2013 Report Share Posted May 20, 2013 swap in a bullet66 Quote Link to comment Share on other sites More sharing options...
Grey Posted May 20, 2013 Author Report Share Posted May 20, 2013 Yes there is still a need to adjust your chain at the carrier. This is usually run on bikes with long swing arms. If you don't have a really long swinger you probably don't need this tdod101. Quote Link to comment Share on other sites More sharing options...
tdod101 Posted May 20, 2013 Report Share Posted May 20, 2013 Ah okay, I see. Thanks anyways Quote Link to comment Share on other sites More sharing options...
thomas h. Posted May 22, 2013 Report Share Posted May 22, 2013 This iteam will save your cases and you will get longer sprocket life. Quote Link to comment Share on other sites More sharing options...
fappy'97 Posted May 22, 2013 Report Share Posted May 22, 2013 This iteam will save your cases Explain. Quote Link to comment Share on other sites More sharing options...
Trapshooter Posted May 23, 2013 Report Share Posted May 23, 2013 What length swing arm do you need to run this ? At what point is it necessary ? Quote Link to comment Share on other sites More sharing options...
Boo_69 Posted May 23, 2013 Report Share Posted May 23, 2013 PM sent Quote Link to comment Share on other sites More sharing options...
blast off Posted May 23, 2013 Report Share Posted May 23, 2013 This iteam will save your cases and you will get longer sprocket life. Jesus, it's not a case saver. It's just a tensioner for bikes with extended swingers. Quote Link to comment Share on other sites More sharing options...
