Stock pistons or aftermarket.
The 110 rods put more side load on the cylinder walls causing the bores to egg shape, but they rev up faster and you can run stock pistons...... The 115 rod set up which you will need wiseco 795 series pistons for will last a lot longer without having to be rebuilt.. I'd go for longer life, rather than trying to save a few bucks.
New pistons are like 200 bucks. If thats gonna break your budget stay with the stock crank and get your motor ported. Pipes and porting cost some coin but the best bang for your buck, of course if you can afford it get the 4mil cause once you port your cylinders for the stock crank most of the time you can't upgrade later without buying new juggs.
I built my 4mill over this winter, with all the supporting mods that go along with it, i'm $2300.00 into my motor..
