EvilCerberus Posted May 11, 2013 Report Share Posted May 11, 2013 Ok so I took the bike out for a ride and after the shee was really good and warm, the right side started to smoke really bad, I beleive with it being white as clouds that it is antifreeze. After pulling the head I dont see anything that would suggest a antifreeze leak unless it is a pin hole. This is the head Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 11, 2013 Report Share Posted May 11, 2013 Should have done a leak test first. May very well be rt crank seal and you're sucking trans fluid. Quote Link to comment Share on other sites More sharing options...
EvilCerberus Posted May 11, 2013 Author Report Share Posted May 11, 2013 This is the other head that I was going to try and see if I got a different outcome Quote Link to comment Share on other sites More sharing options...
edgehanger Posted May 11, 2013 Report Share Posted May 11, 2013 Leak test the motor buddy. Leak test the motor buddy. Leak test the motor buddy Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted May 12, 2013 Report Share Posted May 12, 2013 what do the pistons look like? one have carbon on top and one look washed clean on top? Quote Link to comment Share on other sites More sharing options...
EvilCerberus Posted May 13, 2013 Author Report Share Posted May 13, 2013 Jereme6655 Yes the top of one piston is washed clean and the other one has carbon on top. Funny thing is the cylinder that is burning the white smoke is the one with the carbon build up and the one that is washed it the side that is burning clean no smoke and easy going. Quote Link to comment Share on other sites More sharing options...
rg97 Posted May 13, 2013 Report Share Posted May 13, 2013 the engine is sucking oil from a bad right side crank seal. possibly need new crank. I had the exact same problem when I bought my shee. Cases will need split, this is a long project. took me about 3 months of going out for 1-2 hours once/twice a week. The carbon build up is from the cylinder burning trans fluid. If you feel the need to still run it (please dont!) make sure you check all your fluids Quote Link to comment Share on other sites More sharing options...
rg97 Posted May 13, 2013 Report Share Posted May 13, 2013 dont even bother trying other heads, this is a bottom end problem. there is no antifreeze leak! Quote Link to comment Share on other sites More sharing options...
rg97 Posted May 13, 2013 Report Share Posted May 13, 2013 THe reason I can tell is because when i first bought my shee i would go around my backyard once (its about the size of a football field) and the whole yard would look like it was covered in HEAVY pure white fog. the crank bearings got worn out and destroyed the seal, allowing trans oil in. Dont let the carbon buildup make you think that you need new pistons, chances are you wont. If you needa new crank, I got mine from vitos performance. new stock crank (trued, welded) $350, 4mm short rod $450, 4mm long rod $425. cant go wrong for an extra $100 Quote Link to comment Share on other sites More sharing options...
spurdy Posted May 13, 2013 Report Share Posted May 13, 2013 Could also be something came loose inside the clutch cover and damaged the crank seal allowing gearcase oil into the crankcase. But in either case, sounds like oil to me. If it was water from the head gasket you could have check for bubbles in the radiator with the cap off before you took the head off. A leak test will tell you if it is air tight as has been said multiple times. SP Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted May 14, 2013 Report Share Posted May 14, 2013 Travis, Bring it by and work on it here. I've got all the test equipment you'll need. Shouldn't take more than a day to get you going. Say one of the next Friday's you have time?? -Brandon Quote Link to comment Share on other sites More sharing options...
EvilCerberus Posted May 14, 2013 Author Report Share Posted May 14, 2013 After checking my engine over I found that I have the exact amount of tranny fluid in it that I put in it. But my antifreeze is about a pint or so. no where near what i put into it. Thanks Brandon for allowing me to come down and work on it but I will not have time to do that before the ride in two weeks. So looks like I will have to bring it with me and see what we can get done. I would really love the help though. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted May 14, 2013 Report Share Posted May 14, 2013 Let me see if I've got this straight. You're gonna take a broken bike to a ride, and expect your friends to take time out of their riding to get your bike running? You've got 2 weeks. Fix it. I've worked ALL night before a ride, working on my bike, and rode the next day with no sleep, while my friends are drinking their Dutch Bros and bitching about how tired they are. Quote Link to comment Share on other sites More sharing options...
EvilCerberus Posted May 14, 2013 Author Report Share Posted May 14, 2013 No Starwriter you seem to have it all fucked in your head. I am going to take a bike down to a ride and work on it. I will pick the brains of my friends while we are sitting around the fire at night or having a bite to eat for lunch, so that I can find out what is going on and try to get it fixed before the ride is over. Besides that my firend has the tools that I need to fix said bike I just have to find the time to go to his place to use them. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted May 14, 2013 Report Share Posted May 14, 2013 OK, whatever you say. I just see it going this way. "Hey dude, how was your ride last weekend?" "Oh, pretty good. I got suckered into helping Evil build a motor, in camp, Saturday" "Wow, he blew up a motor? Bummer!" "No, he showed up with the head off the bike and asked if I knew what might be wrong" "What? He took a fucked up bike to the ride?" "Yep, and he knew about it 2 weeks ago. I told him to bring it over and we'd check it out, but his ol' lady was bitching at him about not spending enough time with her" "Man, that sucks! Gotta feel sorry for the guy" "Yeah I know, but his woman is smokin' hot lookin' so I guess that's what it takes to make her happy" "OK....... I guess" Quote Link to comment Share on other sites More sharing options...
