bansheegoon Posted May 9, 2013 Report Share Posted May 9, 2013 1. Is it safe to remove and install flywheel(magnet around stator... magneto???) With an impact wrench just safe to at least remove? 2. How tight should I be tightening my rear swinger to the frame? Seems to be some slop side to side compared to my Buddy's bike. Should I be clenching the frame till it tightens up on the swinger? Thanks guys! Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted May 9, 2013 Report Share Posted May 9, 2013 you can use an impact, shouldn't need too. make sure the flywheel puller is screwed as far as it can be into the flywheel. only use the proper puller. The swingarm is only torqued to like 68 ft lbs if i remember right,that i use an impact anyway. It should have a shim (washer) behind each bearing seal end cap, look to be sure. Swingarm should be snug sliding into the frame. Quote Link to comment Share on other sites More sharing options...
bansheegoon Posted May 9, 2013 Author Report Share Posted May 9, 2013 Missing the shim washers thanks for the heads up and I don't understand by looking at this why I need a puller I took the nut off its on the shaft really tight Quote Link to comment Share on other sites More sharing options...
bansheegoon Posted May 9, 2013 Author Report Share Posted May 9, 2013 Is it pressed on? How am I gunna get it on my 4mil? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted May 9, 2013 Report Share Posted May 9, 2013 Flywheel - tapered shaft, press fit Quote Link to comment Share on other sites More sharing options...
possum Posted May 9, 2013 Report Share Posted May 9, 2013 The puller threads into the flywheel. You will see threads inside the flywheel center. Quote Link to comment Share on other sites More sharing options...
bansheegoon Posted May 9, 2013 Author Report Share Posted May 9, 2013 I just found a thread for it thanks anyways I'm getting the pulled tomorrow super easy at least! Quote Link to comment Share on other sites More sharing options...
bansheegoon Posted May 9, 2013 Author Report Share Posted May 9, 2013 Puller* Quote Link to comment Share on other sites More sharing options...
spurdy Posted May 9, 2013 Report Share Posted May 9, 2013 Yeah, don't try a 3 jaw or to pry it off. The puller is cheap and all the other ways have a high likelihood of damaging the flywheel. Also, when using the puller, clean the flywheel threads really good and use a little grease on the threads of the puller. Then make sure it threads ALL the way in (left hand threads) otherwise you may pull the threads if it hasn't been off in awhile. SP Quote Link to comment Share on other sites More sharing options...
bansheegoon Posted May 9, 2013 Author Report Share Posted May 9, 2013 Sweet that's what it said on the thread I found thanks Quote Link to comment Share on other sites More sharing options...
