h20dies Posted May 7, 2013 Report Share Posted May 7, 2013 So idiot friend of mine was riding my banshee hit power-band and lost control, hit a tree busted my steering rod that goes to the right tire... It busted it where the join is on the right tire the bolt that connects the 2. Soo what is this called how i do i get it and fix it? Quote Link to comment Share on other sites More sharing options...
blue97shee Posted May 7, 2013 Report Share Posted May 7, 2013 huh??? Take us a pic or something....we cant tell what you're talking about. Quote Link to comment Share on other sites More sharing options...
h20dies Posted May 7, 2013 Author Report Share Posted May 7, 2013 http://i1356.photobucket.com/albums/q740/christian_hall2/20130507_161421_zpscdf43625.jpg Quote Link to comment Share on other sites More sharing options...
blue97shee Posted May 7, 2013 Report Share Posted May 7, 2013 you need an outer tie rod end, and a tie rod if you dont feel like drilling the old rod end out. Honestly its not worth the effort, just buy a new one. Quote Link to comment Share on other sites More sharing options...
blue97shee Posted May 7, 2013 Report Share Posted May 7, 2013 take the cotter pin out of the broken end (on the spindle the tire mounts to) unbolt the nut and get the broken piece out. you can either unscrew the rod from the other end to get it off, Loosen the jam nut right at the end of the rod or you can get the inside end off the same way the broken outer side came off. Might cost ya like 40-50 bucks to fix. You might wanna check your frame around where the a-arms mount for it being bent. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted May 7, 2013 Report Share Posted May 7, 2013 You need a new "tie rod end". They are left hand thread and right hand thread. Make sure you get the correct one, or just buy 1 of each to be sure. To get it out of the steering arm, remove the castle nut and whack the steering arm on the SIDE. that sorta squishes the hole and spits out the tapered part of the tie rod end. If it doesn't pop out after a few whacks, hit it on the end of the threads. It's junk anyway. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted May 7, 2013 Report Share Posted May 7, 2013 Also with a hit that hard, I bet the steering stop got bent forward and smooshed on the edge. If so, bend it back, weld in a gusset, and build up the smooshed edge with the welder. 1 Quote Link to comment Share on other sites More sharing options...
blue97shee Posted May 7, 2013 Report Share Posted May 7, 2013 http://www.ebay.com/itm/All-Balls-Tie-Rod-Ends-Kit-Set-Pair-Yamaha-Banshee-1989-2006-/140950979581?pt=Motors_ATV_Parts_Accessories&hash=item20d15543fd&vxp=mtr http://www.ebay.com/itm/Yamaha-Banshee-Big-Bear-Wolverine-YFZ-350-Tie-Rod-/261192266870?pt=Motors_ATV_Parts_Accessories&hash=item3cd045b476&vxp=mtr put the new ends on the used tie rod.... Quote Link to comment Share on other sites More sharing options...
blue97shee Posted May 7, 2013 Report Share Posted May 7, 2013 agree with starwriter. Quote Link to comment Share on other sites More sharing options...
blue97shee Posted May 7, 2013 Report Share Posted May 7, 2013 Oh, BTW, friends don't let uneducated friends ride banshees. At least not yours. HAHA Quote Link to comment Share on other sites More sharing options...
