smurph317 Posted May 5, 2013 Report Share Posted May 5, 2013 Ok I just put my banshee together I replaced shifting forks , all shifting linkages , new crank (stock ) fresh bore with new pistons , it has the same dg exhaust as it had when I tore it apart ( I know it's not the best ) I also have a k&n air filter . I installed a few mods to try : adjustable stator plate which I am running at + 5 and I installed a single carb kit . With a 34 mm keihnin carb ,I had the head shaved .030" & the flywheel is lightened .It runs ok doesn't want to idle and it cuts out on acceration . I'm not sure what jets are in the carb . Does any one know what I should be running ? At least close ? I live in Ohio Quote Link to comment Share on other sites More sharing options...
Sandking Posted May 5, 2013 Report Share Posted May 5, 2013 Try a 42 to 45 pilot, eej or eek needle, and 185 main. Then do plug chop Quote Link to comment Share on other sites More sharing options...
smurph317 Posted May 5, 2013 Author Report Share Posted May 5, 2013 Plug chop ? Quote Link to comment Share on other sites More sharing options...
bansheegoon Posted May 5, 2013 Report Share Posted May 5, 2013 Search plug chop on YouTube. You want to see a Caramel color Quote Link to comment Share on other sites More sharing options...
stealthboy Posted July 25, 2014 Report Share Posted July 25, 2014 I have a similar set up in ohio....what did you end up with? Quote Link to comment Share on other sites More sharing options...
